What does this bolt do???
Old May 20, 2019 | 06:16 PM
  #31
Originally Posted by Cat Man HHR
After another post by this person, we found out it was an oil pan bolt.
He showed a very good picture of it broken in the pan rail.
The bolt is in front of the flywheel.
If you are talking about the pic in #23; Where do you see an oil pan? I can see the starter ring pretty clearly through the hole.
Old May 21, 2019 | 02:29 AM
  #32
Don, it is the LONG oil pan bolt - the picture shows the BOTTOM of part of the engine, and part of the transmission.
The oil pan is to the RIGHT in the supplied picture.
You can see the starter in the lower right, and the ring gear is visible through the inspection hole.
The oil pan is directly below the starter.
Here is a flipped version of the original picture that shows a different perspective that may make more sense to some:
Old May 21, 2019 | 07:29 AM
  #33
And note the part number stamp , the picture is flipped .
Old May 21, 2019 | 02:42 PM
  #34
Cat Man HHR's Avatar
Yes the picture is backwards.
Old May 21, 2019 | 07:32 PM
  #35
I don’t see where that long stud can go there, the flywheel is right there and therefore the clutch cover plate would be in the way.
Old May 21, 2019 | 10:25 PM
  #36
Goes here.
Old May 22, 2019 | 06:22 AM
  #37
Ah, that’s it! Well done FMG well done!
alien_sporez
7
Apr 3, 2007 06:15 PM
Nazramoth
Mar 1, 2007 04:46 PM
dnvachon
2.4L Performance Tech
Sep 27, 2006 07:54 PM
slamed87lincoln
May 8, 2006 04:47 PM
fubar
Feb 20, 2006 02:13 PM
