Leak in back of HHR
Old Jun 19, 2025 | 08:50 PM
The first drawing that greg8453 posted is the fuel feed line. The HHR does not have a fuel return of any sort, the other 3 drawings show the EVAP vapor purge system.
It would be darn difficult to get fuel out of the intake manifold to return to the tank.
Whoever did the title did not know what they were doing. Notice that the title is the only mention of "return".
Old Jun 20, 2025 | 07:55 AM
A fuel smell and also indicate the EVAP canisters seal is missing or the canister is damaged.
Old Jun 20, 2025 | 06:22 PM
jimvw's Avatar
The fuel line will only leak when the ignition is on, and a short while after (until the line is empty). Won't drain the tank.
Old Jun 20, 2025 | 07:05 PM
greg8453's Avatar
The manual shows a lot of info about the return line. Not evap but fuel. Is the manual wrong. I don't remember a lot about the specifics of vehicles anymore. I use the manuals.
Old Jun 21, 2025 | 08:34 AM
Your manual is wrong in regards to HHR. Maybe just nomenclature. There are 2 tubes; 1 is fuel the other is part of the EVAP system that burns fuel vapor. Both flow toward the motor.
MitchellOnDemand has no mention of a fuel return.
EVAP.pdf
Old Jun 21, 2025 | 10:47 AM
  #26
greg8453's Avatar
Charm is wrong. It states under 'fuel system description' The fuel system is a returnless on-demand design.
And further down it has '
Fuel Return Line: Service and Repair
Go figure. I assume they are all the same.
Old Jun 21, 2025 | 03:44 PM
  #27
The line with the yellow label is the pressurized fuel line going to the injector log, the other line is the vapour line connecting to the Evap purge valve then to the intake manifold, no connection to the fuel of any kind.
Old Jun 21, 2025 | 03:46 PM
  #28
Here’s the other end of that vapour line it connects to the EVAP canister up under the rear axle area of the HHR
DangerBoy
Apr 18, 2022 05:38 PM
TechBill
Apr 8, 2022 08:54 PM
slanwar
Mar 22, 2015 08:03 PM
Pancakes
Sep 19, 2014 12:34 PM
Wolfie
Oct 9, 2010 08:54 PM
