Odd bits from Timing cover/crankshaft
Old May 20, 2025 | 03:30 PM
  #31
I would probably replace those balance shaft sprockets. The one has come apart, don't know if it still functions properly. Is the other one going to come apart?
The crankshaft sprocket, if you can find one that's correct, I would replace also.
Old May 20, 2025 | 04:49 PM
  #32
mhSS's Avatar
Yeah the timing chain being as loose as it was wore the face of that balance sprocket until it couldn't hold on anymore. The race thingy probably was part of it too, Ill be checking up on the intake balance sprocket and timing chain sprocket. Thanks for the all the help!
Old May 20, 2025 | 05:08 PM
  #33
There should be 2 very thin spacers on the crankshaft. I believe 1 goes between the sprockets and the other goes over the small sprocket.
oncewas
Jan 3, 2024 04:16 PM
guppy
Mar 7, 2023 08:17 PM
fastsuv
13
Jun 23, 2020 08:00 AM
Hot Bite
Aug 20, 2018 06:58 PM
Cliffs51
Maintenance and Upkeep
Jul 6, 2018 07:42 PM
