V8 HHR Build
Old Oct 22, 2015 | 06:03 PM
  #661
Boy, the attention to detail on this project is amazing.
Old Oct 25, 2015 | 01:02 PM
  #662
lasater's Avatar
A Couple More Things
As you all know, things are more complicated than the SEMA cars because I want the creature comforts of a real driver, not a concept car. To this end the heater/defroster/a/c system has been extensive. At this point there are no original parts to the system. It's all Vintage Air and Dakota Digital now. Even the a/c condenser in front of the radiator had to be replaced. And of course a custom machined bracket to fit it to the Camaro radiator must be made. It never ends. This first pic shows some of the hoses and the drier for the system.
The Corvette C5 brakes are complete.
Old Oct 25, 2015 | 02:50 PM
  #663
Things never end up like we saw it in our mind when we thought, yeah that'll fit!
Old Oct 27, 2015 | 05:56 AM
  #664
papa_jo's Avatar
won't be long till I'm waiting on you to pick me up for a ride !!!!!
Old Nov 10, 2015 | 07:08 PM
  #665
lasater's Avatar
Stuff Continues......
The final tube in the roll bar system is being fabricated and then it gets painted. Got a delivery from FedEx today, the brand new Air Lift 3H system. I saw it at SEMA and just had to have it. This will probably get installed in a week or two. Then it will pretty much be fabricate a gas pedal and linkage to the throttle body and then get serious again on the electrical. I have alot of help on this but I'm still waaaay out of my league with making this beast run. Also the exhaust system needs to be addressed. I will probably have to run some of the sections with Spintech Oval tubing to get enough ground clearance to lower the car sufficiently.
Old Nov 11, 2015 | 04:05 PM
  #666
papa_jo's Avatar
cool, we getting there
Old Nov 14, 2015 | 09:24 PM
  #667
lasater's Avatar
Exhaust System
The exhaust system will be made of 16 ga. aluminized mild steel. 2 1/2" dia. mandrel bends a straight pieces cut and tig welded together. Once it's welded it will be belt sanded and jet coated ceramic silver. I previously explained, the exhaust needs to come out the sides and not the rear so I had to locate a pair of pretty strange mufflers to fit in front of the rear axle. In front of the mufflers will be a pair of QuickTime low profile electric cut outs. The system will be removable with stainless "V" clamps aft of the cats. Should sound pretty nasty with the cam I'm running.
Attached Thumbnails V8 HHR Build-qtp-qtec66_xl.jpg   V8 HHR Build-sum-622003-ss_xl.jpg   V8 HHR Build-sum-670176_xl.jpg
Old Nov 15, 2015 | 09:20 AM
  #668
those mufflers look similar to the 70 'Cuda mufflers with the side exits in front of the rear wheel inlet and exit both at the front
Old Nov 15, 2015 | 10:33 AM
  #669
rlee63a4's Avatar
That's what I was thinking when I read the post given I owned a '70 Cuda AAR in a previous life. :-) Wish I still had it... :-(
Old Nov 16, 2015 | 06:31 PM
  #670
Cat Man HHR's Avatar
I've been following this and I have to ask. How many people involved in this? And how big is your shop?
