Adding radio buttons on steering wheel
Old Nov 25, 2007 | 12:49 PM
  #431
Pretzel's Avatar
Also the 06 "Details Book" that the GM salesmen study about the vehical has the concept steering wheel buttons.
I like the ones we have now.
YUCK!!!
Old Nov 25, 2007 | 02:01 PM
  #432
courthousedeb's Avatar
Don't like those at all...placement looks weird. Glad we didn't get those.
Old Nov 25, 2007 | 02:30 PM
  #433
TomsHHR's Avatar
Here is a link to my thread earlier this year with button pics in it..
In this thread, I was lucky enough to get a rental 2008 HHR BEFORE they were on the dealer lots. both only had less than 5 miles when I started the rental.
https://www.chevyhhr.net/forums/show...?t=9334&page=2
Old Dec 1, 2007 | 10:56 PM
  #434
HHRAZ's Avatar
Originally Posted by steinywihhr
I just went to my dealership and purchased 3 items.
1. wiring harness
2. switch assembly
3. switch cover
All for less than $65.00
I removed the horn/airbag replaced the harness and installed the switches in less than 10 min.
The only tricky part was removing the horn which I did with a 6” allen wrench that you slide through the two holes in the rear cover of the steering wheel.
Easy mod, love the mute button.
Ok, question.
I have a 2003 Avalanche that I am going to replace with a new HHR SS that is on order. I have a Pioneer AVIC D3 head unit with chevy factory steering wheel controls that are reporgrammed to control the AVID D3. Does the HHR have a similar device?
JV
Old Dec 2, 2007 | 08:44 PM
  #435
Kawtipping's Avatar
Originally Posted by HHRAZ
Ok, question.
JV
I am sure it does, but that would be a question that does not belong in this thread. Try posting your question in the audio section instead.
Old Dec 4, 2007 | 10:46 AM
  #436
Kawtipping's Avatar
Alright, I have verified that the 15234343 is still the correct harness, even though GM's own internal parts help line says it isn't. Now I will be ordering the buttons and cover. I will post up part numbers and a pic or two when I start putting things together.
Old Dec 6, 2007 | 07:26 PM
  #437
Pretzel's Avatar
Hello Kawtipping,
I hope you have better luck getting your 07 cover than I did. After 5 months with the dealership parts department and GM customer complaint hotline. I finally got mine when they ordered the entire streeting wheel and removed the radio bezel. I got a free set of buttons because they didnt want to seperate it and possibly braking it. My cover was silver..and I think GM still dosnt know the correct part number ???
But again this bezel was new for 07 and I see other 08 models are using the same bezel such as the Vett and the Malibu.
2008 Malibu
Craig~
Old Dec 7, 2007 | 09:09 PM
  #438
Kawtipping's Avatar
Originally Posted by Pretzel
Hello Kawtipping,
I hope you have better luck getting your 07 cover than I did. After 5 months with the dealership parts department and GM customer complaint hotline. I finally got mine when they ordered the entire streeting wheel. My cover was silver..and I think GM still dosnt know the correct part number ???
But again this bezel was new for 07 and I see other 08 models are using the same bezel such as the Vett and Malibu.
Craig~
Well, I will know sometime next week. I talked to my dealer today to see if they came in. Unfortunately they were not in the local PDC (think warehouse). I should have them by mid next week though. Once I get all the parts, I will gladly put up the part numbers for everyone else.
Last edited by HillsdaleHHR; Dec 8, 2007 at 05:39 AM. Reason: Remove pic from quote
Old Dec 9, 2007 | 05:30 PM
  #439
pg318's Avatar
Got mine fitted today. Since I had to pull the pins out of the connector to rearrange them for the early build I apparently have, I could feed them through the gap behind the wheel frame, and into the clips on the rear cover, then reinsert them into the connector body, but I found that the leg that goes to the radio controls side was too short to fit comfortably that way, so I rerouted it over the frame.
All worked well aftewards.
Old Dec 12, 2007 | 05:38 PM
  #440
Kawtipping's Avatar
Alright, I have my parts...but don't have them installed yet. Part numbers (and pictures) are as follows.
Switch : 15942446 [IMG][/IMG]
Cover : 15234337 [IMG][/IMG]
Apparently I can not just upload a picture, so you all don't get them. The cover is a darker silver type color (which is why a picture would have been so much better).
