Adding radio buttons on steering wheel
Old Aug 28, 2011 | 11:32 AM
  #691
coolzzy's Avatar
anyone know if there is a different part number between the flush buttons (06style I think) and the newer raised buttons? mine came in yesterday and I installed them, to find out I got the flush buttons, which don't match the raised buttons of my cruis control on the other side. I had to change the order of the pins for the cruise control to match my old harness but that was no sweat. All works, I'd just prefer both sides to match......
PS, it took longer to find the stupid ABS fuse that I popped out under the hood and dropped, than it did to do this mod, I didn't even disconnect the battery....
Old Aug 28, 2011 | 04:36 PM
  #692
Sure would be helpful if people would post part numbers with their "complaints", so that people who want that item (charcoal, chrome, hi-button, .etc) would know what to order!
Old Aug 29, 2011 | 07:05 PM
  #693
coolzzy's Avatar
I ordered as follows:
15234343
15842365
25812392
and got flat buttons, charcoal wheel cover, and wire harness. The wheel cover and harness were correct for my grey interior/wheel HHR. The buttons are of the style from an 06, whereas my 07 has the raised buttons on the cruise side. The new buttons work great though, I would do it again in a heartbeat!
BUT, if anyone has the correct part number for the raised buttons I'll order those and swap out...
Old Sep 6, 2011 | 01:18 PM
  #694
drummerboy0088's Avatar
If anyone is looking for part 25812392 (dark gray cover) I have one i'm looking to get rid of. I needed the silver/nickel cover but ordered this one by accident. I posted it in the classifieds https://www.chevyhhr.net/forums/show...690#post587690
Old Sep 20, 2011 | 05:38 PM
  #695
dudeasif's Avatar
Did this steering wheel swap the other day, i got a leather wheel from a cobalt on ebay, put it in my hhr and now my service air bag light on....uughhhhh
dont understand why since all i did was unplug the air bag, swap the wheel, plug the air bag back in.......
any help?
Old Oct 3, 2011 | 07:03 AM
  #696
1970judge's Avatar
What page are the install pictures on? I don't want to flip through 70 pages! From what I gather..
How are you getting off that center piece? Pics of that?
Old Oct 29, 2011 | 06:08 PM
  #697
GriffingR's Avatar
Originally Posted by courthousedeb
Edit: 7/10/06 to put in instructions for blondes like me.
Kudos to CH and MikeX for answering my dumb questions during install.
Before starting, you may want to disconnect the negative battery cable, but that is a personal decision.
1. Eat your wheaties and take 2 of these before starting.
If you smoke...take your cigarettes with you...you're gonna need them to calm your nerves.
2. Put the switch assembly into the new cover and make sure everything snaps into place.
3. Insert an allen wrench or other small metal object straight into one of the little holes and push towards center of the steering wheel and you will feel the clip move, that holds the horn assembly in place.
4. Apply pressure to the allen wrench/metal tool, holding it in place with one hand and use other hand to apply pressure inward until clip holding it in place releases. Clip is made out of metal, so it takes some strength in order for it to release. (This is why you needed the wheaties. )
5. Once enough pressure is applied, the clip will free itself and then you can do the same thing to the other side.
6. Once both sides are free, let the horn assembly hang by the wires during remainder of this process.
7. Take a phillips screwdriver and remove the covers from both sides...trust me, it makes things much easier to work with.
8. Once you have these out, you will be able to remove the harness ends much easier. Have the new harness handy, so you can see the 3 harness ends you need to remove from the steering assembly. The ones that go behind the brackets are a PITA to get through the steering column hole, so cut those hummers off and save yourself a lot of aggravation.
9. Using a small screwdriver or other metal object, gently lift up on the retainer that holds the last harness end in and pull it straight towards you until it has freed itself. Throw it as far as you can...it will make you feel better. Have another cigarette.
10. Plug all the harness ends into their corresponding places.
11. Put the switch covers back into their respective places and tighten them down. Then stash the wires back into the open areas on each side so they are out of the way.
12. Take horn/airbag assembly and gently push it back into place until you hear it snap into place and you are done, unless you disconnected the battery cable.
Turn the igniton and radio on and test to make sure everything works. Mine did and I nearly fell out of my HHR. This mod is great and I love it already. My boyfriend was totally amazed when he came back home and found that I had actually accomplished this task. He was there when I started, but I told him to leave, as he was making me very nervous and I didn't think he needed to learn any more swear words than he already knows.
Now...on to the install photos provided by steiny.
Is the plug in step 9 the middle one with the blue plastic cover/retainer? I'm trying to figure out how to remove it without destroying it. The one I pulled at the junkyard almost came out in pieces, I need one of them intact...
Old Oct 29, 2011 | 09:04 PM
  #698
prod's Avatar
Does this pic help?
Gotta lift the retaining clip with a sharp tool, but its kinda inside the outer housing.
Old Oct 30, 2011 | 12:14 AM
  #699
iroga65's Avatar
any help?
After replacing the steering wheel airbag lights Service.Buttons on steering wheel working.Help me.Sorry for my english.
Old Oct 30, 2011 | 06:17 AM
  #700
GriffingR's Avatar
I think I understand now. Will let you know how I make out When I get back to this project.
Thanks!
