Fuel line follies!
#91
Like some mentioned above, IMO, it's best to just replace entire line, from engine to tank. It will probably be just as quick and when I replaced mine, there were suspect sections from the bend to the end, plus it just seems like splicing wasn't the way to go. I did go with the stainless steel line which is harder or impossible to put in the stock mounts but it was no problem with the provided clips.
#93
So this kit graphs the lines in just under the driver's seat. Has anyone had problems with the fittings provided? The fittings provided fit the hard lines perfectly that I cut under the vehicle. But trying to insert the tubing in the kit into the fittings provided in the kit was a no-go. The hose was slightly larger than the whole in the nut and the nylon feral provided. Had to improvise but just wondering if anyone else came across this.
Grizzly old man
Maintenance and Upkeep
28
11-13-2015 12:16 AM
SSROADSTER
"How To" Tutorial Library
04-16-2011 03:05 PM
