100k and still kicking!
Old Mar 14, 2016 | 08:48 AM
jdobbins's Avatar
Question 100k and still kicking!
Hello all, couldn't find this in my couple page search so I started a new thread. Hope no one minds.
I just hit 100k miles on my '09 HHR, and it just so happens that it lined up with an oil change and new tires/balance/align.
My question is; what else? Has anyone replaced anything at 100k? Swapped up how you did certain milestones?
Just wanting to see what everyone else started thinking at 100k to keep the HHR kicking for another 100k miles! (If no one can tell already; I am a computer guy, not a car guy)
Thanks, JD.
Old Mar 14, 2016 | 10:01 AM
Plugs at 100K, trans fluid and filter 100K (if severe service). Check you Owners Manual (link in my sig).
Old Mar 14, 2016 | 10:13 AM
jdobbins's Avatar
Thank you for the manual donbrew. Seems like it just mentions what you said plus to replace the engine air filter.
Looks like I know what I am doing this weekend. Appreciate it!
Old Mar 14, 2016 | 10:47 AM
I searched 100,000 mile, this popped up on first page half way down!
https://www.chevyhhr.net/forums/gene...00-plus-35692/
Congrats on your mile-stone!!
Old Mar 14, 2016 | 10:52 AM
jdobbins's Avatar
Search box.... I should have thought about that....
Thank you very much!
Old Mar 14, 2016 | 10:58 AM
No problemo, let me know if you want me to merge this to that thread for you!
Old May 9, 2016 | 02:18 AM
hhrumadbruh's Avatar
I just hit 100k too!
Nothing wrong with my baby except the alignment...which I swear only became an issue after taking it to firestone to prevent anything form happening.
Also there is a slight tug when I exit 1st gear.
Car used to be a rental then we got it at 40k
Old May 9, 2016 | 07:47 AM
HHRs DO NOT need alignments!!!!!!!!!!! The only thing that can be changed is the toe, if that is not in spec some parts need to be replaced.
When someone aligns the front end with bad parts installed the alignment will forever be off.
Old May 9, 2016 | 11:02 AM
aradmahogany's Avatar
HA as soon as I read the part about alignment in the OP's post I knew it was only a matter of time that donbrew would step in and mention, for about the billionth time, that HHR's don't need alignments.
Old May 9, 2016 | 02:07 PM
Well they do if you change out the tie rod inner or outer ends!
But no caster or camber adjustments!
Just toe adjustment
camaro98z28
Jun 23, 2017 02:32 PM
canroc
Sep 18, 2014 04:29 PM
chevyss
Oct 20, 2013 11:02 AM
hurst2001
Aug 10, 2010 09:29 PM
dchris1918
2.0L Performance Tech
22
Aug 25, 2009 06:57 PM
