Oil Change question.
So, we just bought a 2008 HHR LT with the 2.4 Engine. I changed the oil in it as soon as we got it. It currently has 107,000 miles on it, and it’s time to change the oil again.
The person we bought it from kept the oil changed regularly. They had receipts from any maintenance done on the car.
But, what I had noticed, is that the car burns a lot of oil. Since the last change, we’ve had to add 2-3 Quarts.
The car has always used conventional oil. And I’m trying to figure out if I need to switch to either a Full Synthetic or a High Milage Oil.
Just trying to see if any can get any advice or any pointers from someone who has had this issue.
Thanks in advance!
Thanks in advance!
Any noticeable oil leaks or smoke from the exhaust?
Synthetic oil is a much more advanced product and better over the life of the oil between changes.
I am sure you can find some YouTube tests comparing the two.
And I’ve not notice any smoke from the exhaust.
Yeah, I’ve been doing quite a lot of research on the issue. And I’ve seen some pretty mixed results. Mostly noticed that Synthetic can make small issues seem bigger. Found some forums where someone said they still had the burning oil after switching to Synthetic, too.
thanks for the help!
Read this,
https://www.chevyhhr.net/forums/2-2l...ormance-58332/
check for oil in the throttle body , it might be getting sucked into the intake manifold and pooling
Creole Dude
Jul 28, 2016 08:46 PM
badassbowtie
Maintenance and Upkeep
23
May 12, 2013 02:01 PM
fastdogs
Dec 24, 2008 07:57 AM
Black Rose
May 14, 2008 07:44 PM
