08 HHR won't start?
Old Apr 19, 2009 | 04:01 PM
  #31
TomsHHR's Avatar
Originally Posted by Daddy4life85
Like I stated before the factory alarm system is not really all that great. I don't even consider it an alarm system, at best it's a Theft Deterrent Device. If you break a window on the car the alarm does not go off, if you open the door the alarm does not go off. ...... If someone broke out the rear window it wouldn't be hard to pull everything out. So maybe you feel that the factory alarm is good for you but in my experience its not for me.
Are you sure that if you lock the doors with the FOB or the door lock switch, leaving a window down, then pull the lock up and open the door the alarm will not go off?
Mine does...
Old Apr 19, 2009 | 05:02 PM
  #32
Daddy4life85's Avatar
Well I wouldn't say it's poor it's just not as nice as what you can get aftermarket. We are actually putting a radar in it that if someone gets within a foot of the car or so it will give a warning and if the window is left down for some reason and they stick their arm inside the car it'll go off completely. The factory alarm is at least something though.
  #33
Mine does...
It might but if someone decides to not open the door which wouldn't be hard to do then the alarm wouldn't go off.
Old Apr 19, 2009 | 08:07 PM
  #34
09 Panel's Avatar
Alarms only matter if someone is going to respond to the thing going off. Doesn't much happen these days. Owning a bunch of convertibles I've learned the best thing is to not leave anything of value in the car. And the cops will tell you that in most cases the cars that get hit are the ones not locked.
Old Apr 19, 2009 | 09:04 PM
  #35
Ah which is why the alarm we bought is a 2 way paging system :) Tells you if you left it unlocked, or if the alarm is going off all on a neat little keychain pager. Works up to a mile away too.
Old Apr 20, 2009 | 01:44 PM
  #36
Well apparently that part didn't fix it so now they are saying some fuse box under the hood they will replace it tomorrow. Seems as though he's just going through replacing all the electronics lol.
Old Apr 20, 2009 | 01:47 PM
  #37
09 Panel's Avatar
And when the alarm goes off what are you going to do?? Run out there and stop them?? You armed??
Old Apr 20, 2009 | 02:44 PM
  #38
Yes I do CCW but generally someone breaking into a car is not armed.
Old Apr 21, 2009 | 04:16 PM
  #39
Looks like the HHR is fixed. ECU and Fuse box replacement or something like that.
roofer1976
Jan 4, 2014 02:09 PM
spidermanshhr
Jan 7, 2013 09:47 PM
1900colt
Oct 29, 2012 12:01 PM
7734
May 28, 2010 01:12 PM
HillsdaleHHR
Feb 21, 2009 02:26 PM
