ABS & TC light on and off
Old Mar 16, 2020 | 07:09 AM
Lethal Tendencies's Avatar
Ok So I am having the same issue. Sarted about a month ago. Replaced battery,went away for 3 weeks. Came back on this morning.This time cruising around 60 mph the car shuttered and ABS and traction control lights came on. Got to work turn car on and off. Now ABS light on. NO CEL but I checked codes. P0010 pending, camshaft solenoid bank 1
Old Mar 16, 2020 | 07:42 AM
Lethal.
For the P0010, replace the camshaft actuator solenoids. I dealt with that code popping up for over a year. Replaced the solenoids and all is good. My car even runs noticeably smoother. And, best to replace both of them. There is an intake and exhaust side solenoid.
The P0010 code may or may not be triggering the ABS light. Mine never did set off the ABS light. Replace the solenoids 1st and see if it also fixes the ABS issue.
Old Mar 16, 2020 | 07:52 AM
Lethal.
Thanks For the info. Does the SS motor use the same solenoids as the 2.2 and 2.4
Old Mar 16, 2020 | 07:58 AM
Not %100 sure, but I think they're all the same. I only have a SS, so that's what I ordered the parts for.
Guess you could do a part search and see if they list the same part # for all.
Old Mar 16, 2020 | 08:29 AM
Plan on ordering A/C Delco ones from Rockauto
Old Mar 16, 2020 | 08:33 AM
  #26
Don't forget the discount code !
Old Mar 16, 2020 | 08:45 AM
  #27
Anyone have the rockauto discount code? Thanks
Old Mar 16, 2020 | 08:50 AM
  #28
You could look up the thread. It's listed on this site. BUT, I'm a nice guy and since it's sitting right here at my computer (because I had ordered a bunch of parts the other day), here you go.
RockAuto Discount code= D79C50B2AAD900
Old Mar 16, 2020 | 09:01 AM
  #29
Thanks, Parts ordered. I did find that code but was dated Feburary 5th ,so I thought it was out of date.
Old Mar 16, 2020 | 10:44 AM
  #30
That code is good till May 5, 2020
https://www.chevyhhr.net/forums/supp...-2020-a-61707/
handspiker
Oct 29, 2017 09:34 AM
MJC3131
12
Apr 11, 2016 11:10 AM
donbrew
Jan 7, 2015 06:31 PM
canroc
Sep 18, 2014 04:29 PM
ronp
Feb 28, 2013 06:09 PM
