Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Ok So I am having the same issue. Sarted about a month ago. Replaced battery,went away for 3 weeks. Came back on this morning.This time cruising around 60 mph the car shuttered and ABS and traction control lights came on. Got to work turn car on and off. Now ABS light on. NO CEL but I checked codes. P0010 pending, camshaft solenoid bank 1
Lethal.
For the P0010, replace the camshaft actuator solenoids. I dealt with that code popping up for over a year. Replaced the solenoids and all is good. My car even runs noticeably smoother. And, best to replace both of them. There is an intake and exhaust side solenoid.
The P0010 code may or may not be triggering the ABS light. Mine never did set off the ABS light. Replace the solenoids 1st and see if it also fixes the ABS issue.
Lethal.
Thanks For the info. Does the SS motor use the same solenoids as the 2.2 and 2.4
Not %100 sure, but I think they're all the same. I only have a SS, so that's what I ordered the parts for.
Guess you could do a part search and see if they list the same part # for all.
You could look up the thread. It's listed on this site. BUT, I'm a nice guy and since it's sitting right here at my computer (because I had ordered a bunch of parts the other day), here you go.
RockAuto Discount code= D79C50B2AAD900
Thanks, Parts ordered. I did find that code but was dated Feburary 5th ,so I thought it was out of date.
