Charging system problems?
Old Jun 17, 2016 | 08:38 PM
O7hhr's Avatar
Originally Posted by donbrew
Passive sensors don't go bad, it's just a coil of wire around another wire.
More like something is shorting, or somebody has installed an LED incorrectly.
I'll have to check the starter tomorrow.
What do you mean by "installed a LED incorrectly"
Old Jun 17, 2016 | 08:47 PM
If some body replaced an incandescent bulb with an LED without understanding that an LED is a switch that glows when it's on, then you get a short to ground.
Old Jun 17, 2016 | 09:41 PM
O7hhr's Avatar
Oh ok. Yeah no leds on this.
Old Jun 18, 2016 | 09:29 AM
O7hhr's Avatar
Of course today I went to go start the caright AND....it's fine. Goes to 14.3 after starting up, 13.6ish when I turn loads on, and I haven't seen below 11.9 yet today.
I checked grounds again, all secured, check battery voltage 12.5, checked alt 13 even, and checked connections at battery. Everything checks out. For ha has I went to autozone and had them check the system and everything checks good.
I guess I have an intermittent problem, guess I'll just keep driving until it's prominent.
apalknowlie@gmail.com
May 9, 2016 08:33 PM
riceman
Jul 4, 2015 06:02 PM
kmcrae476
May 25, 2015 11:19 PM
GDZHHR
Nov 29, 2013 12:19 PM
TDee1970
Aug 15, 2012 04:58 PM
