Coolant temp sensor wiring
Old Apr 29, 2021 | 01:23 PM
Lt green on 54 is 5V ref. yellow on 45 is CKP signal. ppl/grey on 5 is low ref
Old Apr 29, 2021 | 02:51 PM
Lake Runner's Avatar
Thanks a lot Don!
Old May 1, 2021 | 07:42 PM
Latest update, I believe I have finally fixed this issue. The multiple codes concerning, the ECT, Cam position sensor, Cam solenoids and CKS all boiled down to a broken gasket on the X2 connector
for the ECM that was not allowing the connector to seat properly. Took it for a test drive and all was good. In summary, it is the little things that can easily be overlooked. I replaced my ECM which was having
com loss issues which solved this problem. And I replaced my EBCM as recommended by the Chevy dealer service dept. This solved all the ABS, Traction Control, and ESC warning lights. Now I can replace
the expansion valve and recharge so that my a/c will work again. I appreciate all the help from everyone!
Old May 2, 2021 | 08:46 AM
Vinnybagodoughnuts's Avatar
comandoed
Jul 12, 2020 07:44 AM
cturboaddict
Dec 27, 2019 08:43 AM
Getherdone
Jan 11, 2019 04:05 PM
Greenstu1
Nov 28, 2017 07:42 PM
asanti
Sep 9, 2011 11:08 AM
