CV/Trans Axel question.
Old Apr 13, 2022 | 07:30 AM
  #31
Hvymax's Avatar
Originally Posted by Oldblue
To replace the seals then the cv axles must be removed then reinstalled, but not replaced. Why didn’t your mechanic replace the seals then ? And is it possible he nicked the seals installing the new cv axles
It is fairly easy to replace the seals, here’s a how to from you tube
https://youtu.be/qRQvwAQ8qLg
Why on Earth would anyone go through the trouble to access and replace the seals on a 100,000+ mile car and not replace everything in the path??? On any vehicle I own if I have to do much as break a ball joint loose I replace everything on both sides. The difference in labor is minimal and usually the expensive part. Between 100-150,000 miles the first frontend issue involving bearings, CV's, Seals etc I pull it down and replace everything including Tie rod ends so I won't have to look at it again for years.
I suppose some people enjoy having things to fix every few weeks.
Old Apr 13, 2022 | 10:05 AM
  #32
PulpFriction's Avatar
Those are good points, with one caveat; these days, there are a lot of poor quality aftermarket parts out there, and sometimes the original left in place will outlast a crappy replacement. The example that immediately comes to mine is that it has been reported here that the crank seal that comes with the Fel-Pro engine cover gasket often leaks. So for me, case-by-case after due consideration.
SwaintaN
Jun 14, 2019 04:19 PM
hurst2001
Apr 4, 2019 09:38 AM
m_ridzon
Drivetrain (Excluding Engine)
33
Apr 4, 2019 07:30 AM
purple people eater
Sep 27, 2015 08:33 AM
Waynejwj
Jul 15, 2013 08:06 PM
