Electrical Nightmare
Old Feb 17, 2020 | 05:29 PM
Do the other windows work from their individual switches?
Originally Posted by GreyHHR#2009
No the front passenger and the 2 rear door switches do not work.
Is this the answer to my question? It's not clear, and it may be very important.
Old Feb 27, 2020 | 05:03 PM
GreyHHR#2009's Avatar
Window update
I have power to drivers door and passenger window switches. Hooked a meter to the motor leads and can watch power go positive and negative. Put 12vdc direct to motor and window goes up and down. Hooked connector to motor and it wont move with either switch. HELP
Old Feb 27, 2020 | 05:15 PM
Again, to be clear. Is the only window that works is the front left window, which operates from the master switch. No other windows work from any switch?
Old Feb 27, 2020 | 07:49 PM
You proved that it is the switch!
Old Feb 28, 2020 | 07:09 AM
I have purchased all new from GM window switches( drivers and 3 others).
Only window that moves from the drivers switch is the drivers. The other 3 switches click from the driver's and at each door.
I put direct power to drivers rear motor and it moves.
Checked power lead to motor and voltage switches + - at 12vdc.
Plugged in motor, moved switch motor dont move.
Old Feb 28, 2020 | 07:45 AM
  #26
Only the driver window moves from that switch all other door switch (relays) click from the driver's control.
Old Feb 28, 2020 | 08:23 AM
  #27
Have you read the previous 25 posts? I'm getting the feeling you only read 1 page.
I posted a wiring diagram earlier, which explains why the power an ground at each switch would be good an they still don't operate.
In some of your descriptions you describe the lockout feature. It seems to change. Maybe typing in complete sentences and paragraphs would help us understand; I am too old to understand "text speak".
Old Feb 28, 2020 | 09:02 AM
  #28
I’m still thinking ground wires loose and or damaged.
Can you confirm you have replaced the
Drivers door switch cluster?
the other 3 door window switches?
did you clean the contacts in the old switches
https://www.chevyhhr.net/forums/prob...-switch-46384/
See post #9
Old Feb 28, 2020 | 01:05 PM
  #29
Cat Man HHR's Avatar
See post #25
Old Feb 28, 2020 | 02:21 PM
  #30
correct
