Electrical Nightmare
Old Mar 7, 2020 | 08:22 AM
  #71
GreyHHR#2009's Avatar
It sounds like the only thing you messed with, that would affect the driver window, is the fuses.
Figured out how to take out the BCM. FYI there is no way for anything to knock out the RAP because on my HHR LT the BCM is mounted to a metal plate which protects the back side. Anyway after hooking everything back up and re installing the BCM is when no windows would work.
Old Mar 7, 2020 | 09:30 AM
  #72
Well, that's not what you said before. But whatever you did, go through it again, try to at least get your drivers window back. Maybe you'll stumble upon the fix for the rest of them.
Old Mar 7, 2020 | 10:26 AM
  #73
I hooked up the battery after re installing the BCM and it smoked. I guess I need a new BCM. I dont know why I took it out seeing that I had power at the fuses, that should have ment the RAP was good, correct?
Old Mar 7, 2020 | 11:25 AM
  #74
First time ever unsubscribed a thread.
Old Mar 8, 2020 | 06:34 AM
  #75
Thanks for the vote of confidence. This car is just been a mess. Nothing with it seems to make sense.
Old Mar 9, 2020 | 05:24 PM
  #76
Blue_SS's Avatar
Quoted for posterity.
Old Jun 29, 2020 | 11:54 AM
  #77
Question all my power windows quit working
All fuses and grounds I could find look good.No blown fuses.Connections in fuse box under the hood are all clean and tight.You can hear a click noise from each door switch when you activate them from the drivers door or at each door.There is over 12 volts power to each switch. When i disconnect the lead from any switch and put battery power directly to each motor ,the window goes upor down.I bought all new switches and a battery when this first started just in case. Is there a single point where I can apply power to all 4 switches from the battery? I have a 2009 HHR LT.
Old Jun 29, 2020 | 12:32 PM
  #78
Check the 2 amp RAP fuse in position #17 on the BCM(interior fuse block).
Old Jun 29, 2020 | 12:38 PM
  #79
Welcome to the site, I suggest you, Clean the switch contacts, it’s fairly easy and here’s a how to thread
https://www.chevyhhr.net/forums/www....ad.php?t=62119
Old Jun 29, 2020 | 12:49 PM
  #80
Thumbs up
All fuses are clean and good.There is power to each fuse #17 and I think it was # 30. Im at work and cant see the car. Even checked the fuse under the hood.
