HHR rejected by emissions station
Old Feb 11, 2022 | 05:18 PM
  #41
CP_HHR's Avatar
I have been driving it. I burned out fuse #29 a couple weeks ago when some banana connectors pulled out of the sockets of a voltmeter and apparently shorted out. After putting another fuse in (#29) there was voltage at the power outlet again.
Old Feb 11, 2022 | 05:22 PM
  #42
CP_HHR's Avatar
I found a couple other posts on this forum whille searching for information about it a couple weeks ago about people plugging things into the power outlet and blowing the fuse. I wonder if they checked their OBD2 connectors.
Old Feb 11, 2022 | 06:45 PM
  #43
Might have, might not have.
let’s focus on getting your issues resolved, and the testing passed!
Old Feb 11, 2022 | 07:44 PM
  #44
I think the OBD2 port is working. See those 3 circles, top right of the report? Power train system, antilock brake system, service interval. They all have a check mark. If there were an issue, there would be an X. Like this power train X on the report I recently got at AutoZone.
I would guess that if their reader could not establish a connection with OBD2, there would be a note to that effect, or perhaps all 3 circles would have an X.
I may pull the fuse and go try. Not today though. Well, maybe. I do have to go out tonight.
Old Feb 11, 2022 | 08:20 PM
  #45
On another look, I'm reversing. If the reader was able to communicate, the report would have the VIN. Or did you redact that information?
Old Feb 12, 2022 | 08:29 AM
  #46
There is P2096 on that report. I bet the flex pipe is cracked. The CEL is either broken or lit.
P2096 means there is way too much air in the exhaust.
Old Feb 12, 2022 | 08:34 AM
  #47
RJ, In post #13 , it’s mentioned the VIN information was removed.
Donbrew that report in post#44, that’s from RJ, not from the HHR the OP is having problems with.
Old Feb 12, 2022 | 08:53 AM
  #48
Ok, so the port is working fine then.
Yes, the P2096 was caused by the loose elbow I had installed for the downstream o2 sensor.
Old Feb 12, 2022 | 05:46 PM
  #49
CP_HHR's Avatar
I talked to a mechanic today about the problem. He was busy and he asked if a dash light was on and I said only thing it says is SVC tire monitor and he said it has nothing to do with the emissions. I told him about blowing fuse #29 and replacing it and that might have something to do with the lack of data and asked him if he could check the OBD2 port. He said come back Monday.
Maybe my system works OK. Both the emissions station and Autozone seemed to be able to get some data.
Old Feb 13, 2022 | 03:38 PM
  #50
CP_HHR's Avatar
Originally Posted by donbrew
Why do I care if the Beltsville Self serve kiosk is not working?
Now we know you are in Maryland .
I'm wondering if there is a comspiracy with the emissions tests not working to help get people to buy electric vehicles.
