Ignition Key Stuck, Engine Running
Old Dec 12, 2011 | 11:58 AM
  #41
Rat 427's Avatar
ok, my turn with the ignition switch problems to add to the list. some help form people that had there fixed would be awsome. 06 LT2, ignition will turn off from run to Acc, but not release to off unless i press the manual release button. What parts do i need to fix this exact problem. either from parts lists on warranty/dealer repairs or personal repairs done. i want to do this on my own, as i do not have the 4-500 the dealer just quoted me to try and fix the problems, as they say they do not know what the issue is, like they never even heard of such a thing with these cars. wtf....are they kidding. hate my local dealer. any help would be appreciated.
Old Dec 12, 2011 | 12:09 PM
  #42
Rat..... but the engine is shutting off? Auto, or manual transmission?
Old Dec 12, 2011 | 12:12 PM
  #43
Rat 427's Avatar
yes, the engine shuts off, key just keeps all the ACC accesories hot and on cause it will not return to the off position. to get the key to go the one more notch to OFF, i have to press little manual release buton now. car is an Auto...sorry.
Old Dec 12, 2011 | 12:18 PM
  #44
It's your shifter not actually registering that it's in park more than likely..... Common problem with the early ones.
There's a few threads on the forum about replacing the whole shifter or repairing the plastic bit that breaks.... with the repair you have to make the piece, it's not available separately.
Old Dec 12, 2011 | 12:57 PM
  #45
Rat 427's Avatar
ok, is there a seperate switch in the shifter to register its in park, cause when i put it in park, all the doors unlock, so it is tripping at least that electric switch. is there another that actuated the lock mech. on the dash seperate from the door locks.
Old Dec 12, 2011 | 01:22 PM
  #46
If you didn't have an '06 Rat I'd say your problem lies with the ignition switch/cylinder, but being that its an '06 you may be dealing with the shift interlock issue that cropped up on them.
Here's a link to a thread on that, its a long one but you might be able to glean some helpful info from it including the part number of the revised shifter assembly.
https://www.chevyhhr.net/forums/problems-service-repairs-42/ignition-jamming-3947/
Old Dec 12, 2011 | 02:36 PM
  #47
I don't know if there's more than one switch or not and I don't know if those with the shifter caused "stuck key" issue had their doors unlock when putting it in park..... Look through the link 843 posted and see if it rings any bells. I was looking for the other thread for a bit earlier and didn't find it...... I'll keep looking.
Old Dec 12, 2011 | 04:02 PM
  #48
pitbull76's Avatar
Rat, I had your problem when I had my 06. 843de hit it on the nose. You need a new shifter. It will solve your issues. There is nothing wrong with the lock cylinder. If the cylinder binds, you aren't getting the key out no matter what you do (had that one happen too... lucky me).
Old Dec 12, 2011 | 04:54 PM
  #49
Okay.... Took awhile but here's the repair thread for the shifter.....
https://www.chevyhhr.net/forums/problems-service-repairs-42/shifter-broken-removed-disassembled-fixed-34214/
Quite a bit of $$$avings if you're the handy type.
Old Dec 13, 2011 | 08:52 AM
  #50
Rat 427's Avatar
awsome info guys. thanks. maybe this weekend i can tear into the shifter and verify the part is broken and that is my issue. Lot more help here than at the dealer.
dande54
Aug 11, 2023 09:52 PM
gfsloan77
Aug 27, 2013 08:51 PM
denny
Jun 12, 2012 02:28 PM
dhansen871
Aug 22, 2010 01:02 PM
jethro
Jan 13, 2009 09:34 PM
