No Power at All / Key Stuck in Ignition
Old Dec 3, 2014 | 10:13 AM
In my case the warnings went away after a restart. Don't know about the radio.
Old Dec 7, 2014 | 01:53 PM
DrUnKeN_TiGeR's Avatar
i know on my 2010 i had to push the plug in tighter in the passenger kick plate to get my airbag light to go off when it was on. Once is all it took.
Old Dec 8, 2014 | 07:58 AM
NappiiRoots's Avatar
Would you happen to have a picture of it?
Old Aug 9, 2018 | 11:34 PM
mugwump's Avatar
Red face Key stuck in ignition
Thanks for all the help, there was a small panel right under the steering wheel and I popped it off, gently stuck a pen in it and then turned the key and it came right out.
Went down to the local auto part place got a new battery...problem solved.
Again, thanks so much.
Old Aug 10, 2018 | 08:07 AM
Oh, you read your Owner Manual!
Old Aug 10, 2018 | 09:31 AM
2manyvans's Avatar
My '08 had a new NAPA Legend battery last year, last week same problems as OP . I retrieved it and got a free replacement. Everything good but the tire pressure on the DIC reads psi -- .
The battery I put in my '09 last summer was an AC Delco. No problems Hmmm. Any ideas on the psi readout? thanks john
Old Aug 10, 2018 | 09:48 AM
There is a TSB #08-03-16-001B on 2008 models that lose battery power. You will need to go to a dealer (or someone with access to TIS2WEB) and get upgraded firmware for the RCDLR.
Old Aug 10, 2018 | 02:23 PM
mugwump's Avatar
No, I have no manual, I received the "tip" here. Thank you very much
Old Aug 10, 2018 | 02:50 PM
Online Owners Manuals are available for you to download on this site. Moderator Donbrew has a link in his signature. Click on the link and find the manual for your year model.
Old Aug 10, 2018 | 04:17 PM
My point was that it is in the Owner Manual. No need to search the interwebs if you have one.
dande54
Aug 11, 2023 09:52 PM
gharrison42
Jul 2, 2019 11:45 PM
gfsloan77
Aug 27, 2013 08:51 PM
dhansen871
Aug 22, 2010 01:02 PM
jethro
Jan 13, 2009 09:34 PM
