Oil Leak
Old Dec 2, 2016 | 06:55 PM
The aforementioned filler tube. There is supposed to be a gasket between it and the valve cover. You can just take it off and put the oil cap in the valve cover.
Old Dec 3, 2016 | 12:26 PM
guppy's Avatar
So I fill it back up with oil, took an entire gallon. I get me wife to assist, she cranks it up and I video what I knew was going to be a massive oil leak. I did not see this coming.
http://vid96.photobucket.com/albums/...R/IMG_1225.mp4
Old Dec 3, 2016 | 01:54 PM
Whoever changed the filter needs a "talking to"!
Old Dec 3, 2016 | 02:26 PM
Yeah that doesn't look right. Mine doesn't do that, but it's an SS, so maybe it's different.
Serious though, is the cap broken? Oil was pouring out before the cap was ejected.
Old Dec 3, 2016 | 03:21 PM
And that is the used cap that you used from the 2.4? Go get a new one, as mentioned previously - they are cheap. Hopefully you have not damaged the engine with it running out of oil.
Old Dec 3, 2016 | 05:30 PM
aradmahogany's Avatar
Was that directly after new oil? Looks kinda like a milkshake.....
Old Dec 3, 2016 | 05:44 PM
Just air foamed, clean and check the threads in the block, get a new filter cap and a new oil filter and tighten the cap properly!
Old Dec 4, 2016 | 06:46 PM
Ijazzu's Avatar
WOW ...... That was CRAZY!
Old Dec 4, 2016 | 07:08 PM
Hmm. 2 different oil filter caps and both have leaked. I would be taking a close look at the filter housing itself. You may have a crack there.
The video showing the cap blow out seems as though the cap threads are not catching on the housing threads.
Or maybe the housing threads are stripped.
Old Dec 5, 2016 | 07:31 AM
DrLoch's Avatar
And you caught it on camera... Good thing you were looking
Hellraisehr
Apr 15, 2019 03:48 PM
junker
Nov 18, 2009 12:06 PM
alw
Jan 4, 2009 04:22 PM
stranger
2.0L Performance Tech
7
Dec 1, 2008 04:01 PM
pobryne
Jun 5, 2008 09:47 PM
