Oil leak from oil pressure sensor?
Old May 12, 2024 | 09:59 PM
MJR1970's Avatar
@donbrew I cleaned up the engine and guess what? I see oil seeping from the oil filter cap. I took it off and can't find any cracks. I snugged it down tighter than usual and it seems to not leak. I think I'll go ahead and buy a new cap though. Thanks man and thank you @Oldblue
Old May 13, 2024 | 07:35 AM
That's why filters come with a new O-ring.
Old May 13, 2024 | 08:28 AM
AC Delco sells an oil filter and cap and oring.
For part number reference
Old May 13, 2024 | 09:50 AM
MJR1970's Avatar
@Oldblue I work at a paper mill in maintenance Lubrication. We have kits to custom make O rings. I'm thinking of buying a new cap and then making an O ring with a thicker diameter material.
Old May 13, 2024 | 10:50 AM
Wouldn’t try that. The original or replacement works fine. You either have a cracked cap or bad o-ring. Get a new cap and use the o-ring made for it.
Trying to stuff a bigger o-ring in there isn’t going to work. That would possibly stress crack the plastic cap.
Old May 13, 2024 | 11:17 AM
Why would you even think of making your own? They are provided with a new filter, they must be installed correctly, lots of people fail to put it in the groove.
Old May 22, 2024 | 05:56 PM
MJR1970's Avatar
I just used the one with the new cap.
Finally bought a torque wrench, so I torqued it correctly. No more leak!
Old May 23, 2024 | 07:03 AM
Awesome, thanks for the follow up ! Keep it clean and drive it often!
hotrod
Feb 3, 2024 08:08 AM
teepee2
Nov 13, 2022 06:46 PM
Nazramoth
Jan 18, 2017 01:26 PM
gschroed
Jan 29, 2014 07:24 AM
