Timing chain motor trashed?
yes yours will be like Cloyes. The other gentleman did not know you didn’t have to pull the balance shafts out. 2.0 2.2 2.4 have replaceable gears
You don’t pull the balance shafts to change their sprockets, you remove the retainer bolt, line up a drift in the hole with a sprocket cog, remove the bolt, reverse procedure to install new sprockets.
Lifted1904
Sep 17, 2013 11:09 AM
Old Ray
Jul 1, 2007 06:34 PM
