Traction control and service engine light on in my '09 . It's a manual 4.0. It
Old Dec 28, 2018 | 12:50 AM
guppy's Avatar
Weld the crankshafts together for a straight eight? They used to do that back in the day on dragsters.
You kinda dating yourself there GreyBeard. I saw one of these run down the strip at Houston raceway park in the early 90's. They were obsolete then, it was just for entertainment
Old Dec 28, 2018 | 09:08 AM
The cranks aren’t welded together, but coupled together
Old Dec 28, 2018 | 05:54 PM
Robert Welch's Avatar
It's a 2.2 and when they tried to pull codes at the auto parts, he says he couldn't get a reading. Like the plug itself was bad. I'll have to figure that out before i can pull codes. So that's the next move. Thanks for all the support and I'll keep posting when i figure something else out.
Old Dec 28, 2018 | 06:07 PM
Check the fuse #29 fuse in the under hood fuse box, the one for the power outlet in the waterfall is also power for the OBDII receptacle .
https://www.chevyhhr.net/forums/gene...ii-port-59110/
Old Dec 28, 2018 | 06:09 PM
Check the fuse for the power outlet/cigarette lighter. That fuse also powers the OBD connection. (the connection you plug the code reader into)
Old Dec 28, 2018 | 06:42 PM
  #26
Yes, #29
vrg813
Aug 25, 2018 04:27 PM
purple people eater
Sep 17, 2016 01:07 PM
Cascious King
May 8, 2014 08:50 PM
oldracer
Jan 18, 2014 07:21 PM
mrarff
Jan 29, 2011 05:26 PM
