Water Leak on Passenger Side When Raining
Old May 8, 2020 | 03:06 PM
  #31
A good tech could remove your glass without breaking it. Then install it correctly, but that would probably cost as much.
A hint for future use: glass companies make huge mark ups, so they will usually cut a break to a polite customer. Most will waive your insurance deductible if you ask for it. The only one I have run into that would not waive the deductible is Safelite; and they did once when they screwed my appointment up.
Old May 11, 2020 | 09:06 PM
  #32
LadyBee's Avatar
The new windshield was installed today. I was told I had a definite major problem. Apparently there were skips in the bead around the entire windshield and no sealer where I had the known leak. I thought it was a pretty good deal for $200 even. Hopefully now I can put all the trim back on and get the carpeting to lay down correctly after being pulled up like I had it to dry
Thanks for the help and suggestions! :)
Old May 11, 2020 | 09:43 PM
  #33
Originally Posted by LadyBee
I have a 2009 2LT HHR with about 110,000 miles that has a water leak on the front passenger side when it rains. I have read a lot of the water leak threads here (snip) so I hope to fix this but I need some suggestions.
I attempted to take off the cowl cover but didn't have any luck on my first attempt. The cabin filter is dry. I pulled up the carpeting on that side and pulled up the firewall insulation as much as I can. I sat in the car one day when it was raining and saw water leak from the very bottom of the dashboard right next to the door. There was also a couple spots of water at the seam of the A pillar trim where it meets the trim near the dash. The next day I tried to pour water on the top edge of the windshield and down the side to the cowl but I couldn't duplicate that water drip. I have tried to cover that side of the car with a tarp when it rains but sometimes it still gets wet.
When I cover the car, the cowl is pretty much covered unless there is a hole in the tarp so I don't think the water is coming in there. I was thinking that possibly the windshield seal leaks or maybe the door seal is bad. Any suggestions on how to attack this would be appreciated!
When I bought mine back in 2009, I got a caulking tube of 100% silicone (clear) & pumped a nice bead around the door accordions (the wires run thru) to prevent any possible water invading. I have never had any issues before or since. I thought of it as preventative maintenance.
But sounds like your windshield bead was the culprit. Personally I would still silicone the rubber in the doors.
ericdraven
Sep 3, 2011 11:19 AM
cohutta20
Mar 21, 2011 01:46 AM
JTinVT
Oct 19, 2010 11:31 AM
floridamisfit
Jul 30, 2009 11:29 PM
billbeam
Oct 6, 2008 06:08 PM
