Water pump replacement
Old Feb 26, 2024 | 01:22 PM
It works out cheaper!
Old May 17, 2024 | 09:36 PM
tooter1's Avatar
I'm doing timing chains and the pump here in the next week or so. Hopefully, it'll go well.
Old May 18, 2024 | 07:00 AM
Drain the coolant and the water pump , there’s a drain plug for that. You don’t want coolant in the oil pan.remember you will have to remove the coolant temperature sensor (a 19 mm deep socket) to get to the three 10 mm bolts holding the thermostat housing in position. I reach down from the driver’s side of the engine.
Old May 18, 2024 | 03:37 PM
Gearhead1's Avatar
…the tool
Sorry that happened to you. I had to do the same job, but from these guys I got the heads up warning about the tensioner….so I took a good look and measurements of the tool I rented….and found it lacking. So, I modified it to where these was no possible way it could give the chain any slack. And fortunately I didnt have and chain ti tight whining issues.
The dia. Of the tool was good bit smaller in dia. Of hole thru the cover and also liked about 1/2” touching the water pump sprocket….so I built the dia. Up using aluminum hvac tape to correct dia. and made 1/2” thick plastic shim, got longer bolts for the tool…then when I tighten the tool to the sprocket it had no kind of slack
Chrishhrdude
Feb 11, 2025 08:21 AM
Oldblue
"How To" Tutorial Library
13
Sep 6, 2022 06:31 AM
tsbrewers
Feb 12, 2022 08:41 AM
KCrowl20
Sep 20, 2019 09:27 PM
Grizzly old man
Maintenance and Upkeep
16
Oct 29, 2013 09:01 PM
