Coolant leak somewhere
Old Dec 13, 2022 | 10:03 AM
  #71
hhrumadbruh's Avatar
Ok so I'm take the whole bracket off the engine that go in horizontally or just the 3 vertical bolts?
will I be able to take that whole side cover off to do the timing chain stuff easily enough?
any suggestions on timing chain kits? Going to do water pump and timing chain. Any other stuff I should get?
is there a kit for water pump gaskets? I assume I re use the outer cover
Old Dec 13, 2022 | 10:20 AM
  #72
Originally Posted by Oldblue
Timing chain kit 9-4201SX doesn’t include sprockets, good, cause the 2.0 uses a different sprocket on the crankshaft, so reuse yours
Balance shaft kit 9-4202SX also no sprockets .
and yes there’s a kit for the water pump
Old Dec 13, 2022 | 10:24 AM
  #73
This guy dropped the engine cradle, engine and transmission, not required
You will have room to work and remove the front cover.
Old Dec 13, 2022 | 11:29 AM
  #74
anything else I should get?
Old Dec 13, 2022 | 12:23 PM
  #75
Front guide replacement bolt. A must have!
Valve cover gasket set at your cars age give it a new one!
Same with the front cover, I replaced a 3 month old FelPro gasket with this one.
Front seal another must have, I also replaced a FelPro seal that leaked after a few months.
Old Dec 13, 2022 | 01:26 PM
  #76
Thanks I will add those to the order! What about head gasket?
Old Dec 13, 2022 | 01:59 PM
  #77
Everything you need! Did you read the engine assembly instructions I posted?
Old Dec 13, 2022 | 02:01 PM
  #78
A round trip plane ticket and feed me for a couple of days , I could fly to California to show how to do the job! Lol!
Old Dec 13, 2022 | 02:31 PM
  #79
Lol been sleeping in my car last few days just to get decent sleep for work (4am wakeup) so you're welcome to sleep in my room if you dont mind dogs barking, playing inside, and 4 other people yelling and slamming doors all the time 😏
Do you think I need the head gasket? It's kinda pricey. Should I wait and see how it looks?
I think i can manage the jobs by myself lol im pretty mechanically inclined.
Old Dec 13, 2022 | 03:58 PM
  #80
That kit includes new head bolts and gaskets for tge intake and exhaust manifold, so it’s a good deal , then buying them all separately. You will need a head gasket if you remove the head.
Now if you pull the head to determine extent of damage and can wait to order parts, that’s good too! Why throw parts at it if it’s not worth the repair?
