Doing the Job Chevy won't. Wire Job Step 1 MAP
Being a shopper for an SS, I have read these post with great interest.
I have used this style( http://www.connectorsupply.com/catal...lant-p-83.html ) heatshrink on motorcycle and automotive applications.
It has an adhesive sealer inside to give a water tight seal.
Concerning solder, I hope you can get some old resin core tin/lead solder for your repair.
There is a new lead free solder showing up that takes a higher melt temp, amd is contrary to use.
I have a newbie question--how much does this kit cost ?
for my stuff, I just go to radio shack to by the stuff. I have all kinds of solder and guns / iorns
Does anybody in New Jersey know where I can get the wires properly soldered?
For 3 months last year I've had the same surging problem, and my local dealer rewired both sensors and the problem was solved. However, last week, I lost my turbo pressure (turbo only boost to 5psi and makes some unusual sound) like 2 times, I suspect they did a horrible job. I would hate to go back to the dealer for the 8th time for the same problem and have the problem come back again a couple of months later.
NxlKing2304
"How To" Tutorial Library
66
Mar 1, 2016 07:49 AM
Louvit
Jun 2, 2008 06:12 PM
