Doing the Job Chevy won't. Wire Job Step 1 MAP
Old Nov 18, 2010 | 08:01 AM
  #71
camaro98z28's Avatar
Well, it's been more than 2 months and still no issue with surging after I soldered the wires. Even after washing the engine down twice, I still have had no issues.
Old Nov 23, 2010 | 07:29 PM
  #72
speedwagen's Avatar
Being a shopper for an SS, I have read these post with great interest.
I have used this style( http://www.connectorsupply.com/catal...lant-p-83.html ) heatshrink on motorcycle and automotive applications.
It has an adhesive sealer inside to give a water tight seal.
Concerning solder, I hope you can get some old resin core tin/lead solder for your repair.
There is a new lead free solder showing up that takes a higher melt temp, amd is contrary to use.
I have a newbie question--how much does this kit cost ?
Old Nov 26, 2010 | 02:58 PM
  #73
for my stuff, I just go to radio shack to by the stuff. I have all kinds of solder and guns / iorns
Old Feb 9, 2011 | 10:47 AM
  #74
traketo's Avatar
Does anybody in New Jersey know where I can get the wires properly soldered?
For 3 months last year I've had the same surging problem, and my local dealer rewired both sensors and the problem was solved. However, last week, I lost my turbo pressure (turbo only boost to 5psi and makes some unusual sound) like 2 times, I suspect they did a horrible job. I would hate to go back to the dealer for the 8th time for the same problem and have the problem come back again a couple of months later.
Old Feb 13, 2011 | 05:57 PM
  #75
DMarotta's Avatar
Where are you in AZ? I just moved here in Jan. My car is surging and regularly loses boost after I get it washed I will take you upmon the sodering offer asap!
Old Feb 13, 2011 | 08:45 PM
  #76
Im off of 101 and northern. Not far. Lets take a look and fix this crap. Jeff
NxlKing2304
"How To" Tutorial Library
66
Mar 1, 2016 07:49 AM
Lars on Live
Nov 23, 2010 02:45 PM
StaddyCRIA
48
Aug 16, 2010 07:42 PM
stick
Nov 8, 2008 10:24 PM
Louvit
Jun 2, 2008 06:12 PM
