Front Strut Hat Orientation
Old Aug 2, 2020 | 09:08 AM
Yes, and the body, not out toward the fender. I mention the brackets as when the strut is out of the HHR they give you a point of reference!
the flat spot on the upper bearing plate’s orientation is toward the rear of the HHR, it can be rotated into position to align the 3 bolts , so for instance in the passenger side , before you lift the strut into the fender well, ensure that flat spot is pointing to your left
on the driver’s side it will be to your right, Or towards the firewall
This is my passenger side , flat spot points towards rear
Driver’s side, flat spot points right
Old Aug 2, 2020 | 10:39 AM
I think I'm going to send Oldblue a gallon of degreaser next Christmas...................
Old Aug 2, 2020 | 11:45 AM
That’s rust proof spray, George but thanks anyways
Old Aug 2, 2020 | 12:13 PM
Oops. My bad. We don't use any stuff like that down here in the South .
(I'll make that a gift card for some coffee and doughnuts. )
Old Aug 2, 2020 | 01:41 PM
Thank you, double double!
Old Aug 2, 2020 | 01:55 PM
Cat Man HHR's Avatar
When I replaced my front struts I used the original top plate and don't remember a tab.
I replaced the struts using the original spring with the top plate also.
If I saw a tab I surely would have indexed it correctly.
By the way, don't call me Shirley. Lol.
Old Aug 2, 2020 | 03:34 PM
Perhaps the plate wasn’t disturbed form the coil spring, ergo it was replaced with the original spring on the new strut in the original location.
Another great line from a fellow Canadian, Leslie Nielsen
Old Aug 3, 2020 | 07:28 AM
m_ridzon's Avatar
Opposite of the steering knuckle bracket... Doesn't seem like 12 o'clock.
Yes, it is 12 o'clock by my original post description:
Assuming the strut is installed in the car, looking down from the top when standing next to the wheel, what orientation does the tab point to when installed (e.g., 12 o'clock, 9 o'clock, etc.)?
Old Aug 3, 2020 | 09:49 AM
Ah, yes. I should have went back to the OP.
ITALGT
60
Feb 4, 2017 03:32 PM
BDR1973
Maintenance and Upkeep
35
Nov 6, 2016 12:36 PM
Musicguy
May 1, 2012 09:56 AM
dozol22
14
Nov 20, 2011 06:10 PM
jimieno
Mar 19, 2006 07:40 PM
