Lots of oil in cyl #3
George I understand the last pictures.
That's why I'm suggesting the cleaning of the valves and oil catch can/PCV mod.
Way easier when the engine is on a stand.
If the engine hasn't been pulled, would like to know then, the parts that were removed when done.
Please read our parts listing in this thread , about those ball joints for the FE5 suspension.
https://www.chevyhhr.net/forums/comm...-thread-48833/
Originally Posted by Cat Man HHR;884091
[color=#2980b9
[color=#2980b9
"When you pulled it out the top you said you removed the exhaust manifold and damper.
I'm going to guess it was the turbo and manifold ?
Not just the turbo."[/color]
Thanks
Thanks
With the intake off try and clean the back side of the intake valves.
Remove the internal PCV valve, add an external one and with an oil catch can.
Not just the turbo.
Thanks
Not just the turbo.
Thanks
New engine has only had valve cover removed and timing cover. The rest has been left alone do to budget. I would love to clean the valves but it's just not in my budget.
Your "new" engine with the miles on it will have coking on the intake valves.
How much ? I don't know.
Are you saying you have a cleaning system?
There is no EGR on this engine.
Cleaning the fuel system won't work, as the engine is direct injection.
The oil that cokes up comes from the internal PCV system.
