Lots of oil in cyl #3
Old Jan 30, 2020 | 05:38 AM
  #51
Cat Man HHR's Avatar
George I understand the last pictures.
That's why I'm suggesting the cleaning of the valves and oil catch can/PCV mod.
Way easier when the engine is on a stand.
If the engine hasn't been pulled, would like to know then, the parts that were removed when done.
Old Jan 30, 2020 | 05:50 AM
  #52
Please read our parts listing in this thread , about those ball joints for the FE5 suspension.
https://www.chevyhhr.net/forums/comm...-thread-48833/
Old Jan 30, 2020 | 06:25 AM
  #53
Originally Posted by Cat Man HHR;884091
[color=#2980b9
"When you pulled it out the top you said you removed the exhaust manifold and damper.
I'm going to guess it was the turbo and manifold ?
Not just the turbo."[/color]
Thanks
I was just pointing out your quote above, which was wrong. He has NOT pulled the original engine. Nor has he removed the exhaust manifold which you thought he had. A lot of that misinformation was because of his "friend" claiming things that weren't done.
Old Jan 30, 2020 | 06:30 AM
  #54
OK got it.
Old Jan 30, 2020 | 09:19 AM
  #55
Dark_Knight's Avatar
With the intake off try and clean the back side of the intake valves.
Remove the internal PCV valve, add an external one and with an oil catch can.
Not just the turbo.
Thanks
unfortunately I dont have the money for any of those things or additional gaskets. Being a heart patient and fighting for durability iv lost most my income. But I think I got enough to get this thing running.
Old Jan 30, 2020 | 12:23 PM
  #56
thankyou so much for this. I saved it to my phones home screen. God bless.
Old Jan 30, 2020 | 12:27 PM
  #57
on the bad engine he remove the intake and stuff. He was planning on coming out the top. As it's possible on hhr ss models but much more labor intensive. Base hhr models iv always pulled from the top.
New engine has only had valve cover removed and timing cover. The rest has been left alone do to budget. I would love to clean the valves but it's just not in my budget.
Old Jan 30, 2020 | 12:42 PM
  #58
Dark Knight
You at least can clean the back side of the valves.
No money spent on this, only time.
Old Jan 30, 2020 | 01:05 PM
  #59
Dark Knight
with the intake and exhaust manifolds on. How if I may ask. I has egr and fuel system cleaning system.
Old Jan 30, 2020 | 01:22 PM
  #60
Explain this better.
Your "new" engine with the miles on it will have coking on the intake valves.
How much ? I don't know.
Are you saying you have a cleaning system?
There is no EGR on this engine.
Cleaning the fuel system won't work, as the engine is direct injection.
The oil that cokes up comes from the internal PCV system.
