Overheating ?
Old Oct 31, 2012 | 08:12 PM
  #111
Snoopy's Avatar
Did you snap the filter into the reservoir cap first and then screw it on?
Old Oct 31, 2012 | 08:44 PM
  #112
ScroogeSS's Avatar
Certainly. The cap has a spring that buts into the valve and the valve's assembly contains a spring inside it's assembly. It was that inner assembly that was jammed into the filter opening and the main spring off-centered the whole valve and filter within the block. I ended up getting an AC Delco PF258G (with cap) for $14 at the local auto store. The dealer wanted $25 for just the cap and neither them or any dealer in the Jacksonville (FL) had one in stock. At that price, I didn't want to know how much it and the filter together would have been.
The oil in the picture congealed as it cooled (sludge...). Yuck!
Old Nov 1, 2012 | 12:10 AM
  #113
Yikes !!! The oil looks terrible. You may want to change it more frequently.
Edit: It sure looks like you have more than just oil in that bucket. I bet if you sent out a sample for OA testing, they would find dex-cool also.
As to the oil filter, I always wipe the O-rings with oil, so 'hand turning in' the filter cap is easy & doesn't chaff the O-rings.
You should never have to use the socket or wrench to thread it in. If so, STOP, check it out & try again..
My filter socket is only to give the final snug...
Old Nov 1, 2012 | 12:08 PM
  #114
IgottaWoody's Avatar
If you look at the direction of the folds in the filter pleats you'll notice the folds are in the direction of removal, not installing. After that many heat cycles the filter tends to stick and not want to turn so it folds when removing....
Plus Ive been finding that with the turbo, theres more blowby and the oil suffers..
guppy
Aug 24, 2015 07:29 AM
batsibf
2.4L Performance Tech
14
Apr 26, 2015 11:22 AM
cturboaddict
Aug 18, 2013 09:15 PM
Mr Z
Jul 27, 2012 05:26 PM
TxSkyPilot
Jan 28, 2008 04:54 PM
