GM Recall Campaigns For Information & Discussion of General Motors Recalls
GM Ignition Recall Extended to All HHR's 2006-2011 UPDATED!!!
Old Aug 4, 2014 | 09:06 AM
  #381
nk_'s Avatar
nk_
It took 67 days for my part to arrive. I honestly didn't know if it would ever arrive.
Old Aug 5, 2014 | 08:20 PM
  #382
hhr11's Avatar
Originally Posted by Old Lar
I called for an appointment and was told a couple of weeks. Three days later they said the parts were in. They did the repair, but the new keys would not work in the door lock. The dealer said the door lock cylinder was worn. (?) I bought the HHR new and have used the key to open the door maybe 10 times, if that, in my eight years of ownership. The dealer had to order a new door lock cylinder ( $50+), then charge me $140+ to replace the door lock cylinder.
Lar the GM vin site indicates the repairs/keys for ign and doors are free as below.
Repair Description:
Dealers will replace the ignition cylinder and cut two ignition/door keys and relearn keys, if necessary for each vehicle free of charge. Please contact your local GM Certified Service Dealer to order parts or visit GM Ignition Recall Safety Information for additional information.
Old Aug 5, 2014 | 10:45 PM
  #383
Repair Description:
And the door lock cylinders are NOT part of the recall. Old Lar had the recall work done. The door lock cylinder is an additional part/cost he was talking about.
Old Aug 6, 2014 | 07:46 AM
  #384
manicrodder's Avatar
My car was repaired yesterday. Ignition cylinder and 2 ignition/door keys cut. Also provided reinforced bracket for the dash cubby. All good and no charge.
Old Aug 6, 2014 | 04:41 PM
  #385
I guess whoever got that reinforcer in the mail 4 years ago threw it away (it was a DIY by mail recall).
Old Aug 7, 2014 | 05:22 PM
  #386
scrisp's Avatar
What was the ignition recall supposed to fix?
I have a 2011, and just got home from having the ignition cylinder replaced, and everything seems fine, except that I was curious and went to my driveway and tried to turn the ignition off with the car in drive. It was very easy to flip it to the accessory position. So I tried it again with the car in drive, foot off the brake, and rolling very slowly. Same thing, it would shut the engine off and flip to accessory.
Wasn't it supposed to make it harder to turn the cylinder off while the engine is running, when they replaced the cylinder? Maybe I just had a good one all along, so there is no difference, but just thought that I'd ask.
Old Aug 7, 2014 | 09:25 PM
  #387
LVJJJ's Avatar
Just got my ignition switch fixed, now I can turn the key without jiggling it a lot. Had to make sure I parked with the wheels straight forward or the key almost wound't work. Not exactly sure what the recall was for but I heard that if you had the key on a heavy key ring, it would shut down some systems. Glad to have it fixed cause I kept losing the single key.
Old Aug 7, 2014 | 09:39 PM
  #388
Having tried out the "Recall Replacement Ignition" in a friends SS, it felt very much like my ones that haven't had the recall done yet. His key turns with maybe 5% more effort, by the sounds of the posts above, I think both of y'all might want to head back to your dealers. Something isn't right.
Old Aug 8, 2014 | 07:23 AM
  #389
I didn't think the SS's were involved in the ignition recall, but then again they might be, and X2 take they back to confirm these issues are not normal, I have had the recall done, and I can't turn the key from run to acc or off with out stepping on the brake and shifting into park! 2007 2.2 auto
Old Aug 8, 2014 | 07:29 AM
  #390
Oldblue. Yes, the SS is involved in the ignition recall. They are NOT part of the power steering motor recall.
