GM Ignition Recall Extended to All HHR's 2006-2011 UPDATED!!!
Waited over 5 weeks for my Ign parts.. Then parts came in just over a week ago, so they have informed me.. I have to remember to make an appt to git-r-done.
Snoopy, nice to have good connections..
My dealer only let me drive a mild camaro..
I had contacted my local SoCal dealer concerning my power steering about 6 weeks ago, at which time they took my info to order replacement parts for my ingnition. They called last tuesday, and I made an appt. for thursday ay 8:45am. They gave me a ride back home, and called at 12:30 to say it was complete. They picked me up at home, and I found that they installed a new ignition cylinder, and learned two new keys. (You need to return your old keys.) Even though it wasn't broke - they fixed it.
Now, I have to wait until the EPS parts arrive. Some days it works fine all day, others not so much! 10k miles so far fighting the wheel.
I called for an appointment and was told a couple of weeks. Three days later they said the parts were in. They did the repair, but the new keys would not work in the door lock. The dealer said the door lock cylinder was worn. (?) I bought the HHR new and have used the key to open the door maybe 10 times, if that, in my eight years of ownership. The dealer had to order a new door lock cylinder ( $50+), then charge me $140+ to replace the door lock cylinder.
Did you get a chance to compare the cut of the new keys to the old ones?
You will no longer be able to order a new key using your VIN. The other guy is going to get ripped off, it is possible that EVERYONE on the list is now getting the wrong key cylinders.
If the old key worked, the new key, if cut correctly should have too. If the old and the new keys looked different, they didn't do the ignition swap the way they were supposed to, which was to re-pin the new cylinder to match the old keys. Then the new keys would have worked just fine in the door. I would have asked to see the 'worn' parts in the door lock cylinder.
I haven't heard any more from the dealer on my parts. It's just over a month so I probably have a few more weeks.
