Electrical Nightmare
Old Feb 28, 2020 | 02:24 PM
  #31
GreyHHR#2009's Avatar
Originally Posted by Cat Man HHR
See post #25
All 4 switches are Brand new from sealed in plastic bags and boxed.No signs of any damage to them.
Old Feb 28, 2020 | 02:29 PM
  #32
What I understand:
none of the windows worked from any switch
replaced driver and all 3 other switches
driver window now works
none of the other windows work from any switch
there is good power and ground to all switches
motors work when jumped
there is power from the motors and polarity changes when the switch is activated
No response to the lockout question
No response to the wiring diagram
Sounds like it is not getting full 12,5 volts to motor, what is the condition of the battery?
Old Feb 28, 2020 | 02:36 PM
  #33
So, as you have replaced all four switches in the drivers door cluster and the other 3 single switches, time to test continuity, and look for any broken wires, in the harness from the drivers door to the other three doors, like a common wire broken in the drivers front door harness boot .
I usually find a broken wire in that area
Old Feb 28, 2020 | 02:42 PM
  #34
Since the diagram posted has color codes and pin numbers maybe make sure the wires are where they are supposed to be. GM has been known to use the same connectors with different color codes from year to year.
Old Feb 28, 2020 | 03:29 PM
  #35
Again, to be clear. Is the only window that works is the front left window, which operates from the master switch. No other windows work from any switch?
correct
Old Feb 28, 2020 | 03:32 PM
  #36
when I move the switch in the driver's control I can hear the switch relay in each door click.
Old Feb 28, 2020 | 03:34 PM
  #37
Originally Posted by donbrew
What I understand:
tryed the lock out switch in both positions with no change.
Battery is 1 week old
Old Feb 28, 2020 | 05:19 PM
  #38
Have a look through this thread
https://www.chevyhhr.net/forums/prob...ws-quit-53631/
Old Feb 28, 2020 | 05:23 PM
  #39
What signal is being sent on the mast sw lk wires in both positions?
Are the color positions correct?
Old Feb 28, 2020 | 05:29 PM
  #40
Do the other windows work from their individual switches?
no they do not
