Electrical Nightmare
Old Feb 28, 2020 | 05:47 PM
  #41
GreyHHR#2009's Avatar
Originally Posted by donbrew
What signal is being sent on the mast sw lk wires in both positions?
Are the color positions correct?
colors are correct
A full 12 vdc on the mast
Old Feb 28, 2020 | 05:52 PM
  #42
12vdc on down less than 1vdc on up(all but drivers window are up and wont go down.
Old Feb 28, 2020 | 06:32 PM
  #43
Anything about the fuses in the thread link I posted?
Old Feb 28, 2020 | 07:00 PM
  #44
I asked about the Mast sw lk sig wire. There is one to each of the dfoors. It should change depending on the position of the master lockout switch. I am not sure if it is ground or +.
Old Feb 29, 2020 | 08:16 AM
  #45
Again, to be clear. Is the only window that works is the front left window, which operates from the master switch. No other windows work from any switch?
only the driver window moves and the 3 other switch relays click from the drivers and at the doors
Old Feb 29, 2020 | 09:26 AM
  #46
Ok, that's 3 times you've quoted my post and given basically the same answer.
Old Feb 29, 2020 | 11:35 AM
  #47
The ONLY window that operates is the driver window from any switch. None of the single switches work. The driver gang switch only works on the driver window.
The other widows "click" when the driver switch is used to try them. There are no relays, so it must be the motors trying, thus my suggestion of low voltage.
Old Feb 29, 2020 | 02:26 PM
  #48
Window update
Have you read the previous 25 posts? I'm getting the feeling you only read 1 page.
I posted a wiring diagram earlier, which explains why the power an ground at each switch would be good an they still don't operate.
In some of your descriptions you describe the lockout feature. It seems to change. Maybe typing in complete sentences and paragraphs would help us understand; I am too old to understand "text speak".
Please explain how all brand new switches that are wired to the manufacturer wiring diagram still dont work . Tryed working them with WINDOW LOCK SWITCH in both positions.
Old Feb 29, 2020 | 02:27 PM
  #49
Is this the answer to my question? It's not clear, and it may be very important.
Yes it is the answer.
Old Feb 29, 2020 | 02:28 PM
  #50
Yes that is correct.
