Problem after replacing front hub
I mainly linked that one, just for verification. I've used airtex and they have worked ok, but you never know.
The wheel speed sensor is just odd to me. I mean, I disconnected the right side when I pulled everything apart, but I didn't twist or anything and it's the same hub. I could see it on the left side, since it is a new hub. I'll have to see if I can warranty the left hub, but I am going to inspect the wires and clean the connectors first. This bomber does have almost 190k on the clock.
The solenoids look stupid easy to replace. Which is kinda odd for this car, normally things are a pita to replace because of corrosion. However, the frame bolt for the lca, actually came out without a struggle. I was pleasantly surprised. I see that an oil change is good to do with new solenoids, may as well add an air filter to that.
The How-To section has lots of tutorials.
Solenoid replacement how-to: https://www.chevyhhr.net/forums/how-...13-14-a-28779/
The sensor has no electronics. Continuity ensures that it is capable.
There is also the possibility that water can get into the sensor. If you see problems in wet weather, but not otherwise, you could have a crack in the sensor that lets moisture in.
Wheatgerm
Oct 3, 2017 06:23 PM
Cascious King
Maintenance and Upkeep
Aug 30, 2016 07:10 PM
charhhr06
Sep 12, 2013 03:58 PM
papasmurfsss
Aug 23, 2013 09:49 PM
thebiglion11
Jun 16, 2013 12:49 PM
