Coolant leak somewhere
Old Dec 25, 2022 | 09:16 AM
  #131
I don’t remove the heater hoses or the radiator hose to the thermostat housing, just remove the bolts and move it until the transfer pipe comes out
Old Dec 26, 2022 | 03:02 PM
  #132
hhrumadbruh's Avatar
Ok I think I have found the part I need to loosen
Am I unfolding that green painted bolt to get to the other bolts?
Old Dec 26, 2022 | 03:08 PM
  #133
Ok here is an edit of another image posted above.
just these 3 bolts?
Old Dec 26, 2022 | 04:53 PM
  #134
Definitely can't get to the bolts with everything in the way.
Any suggestions on what to remove to make this possible?
Removing the turbo seems like it would help the most having it out of the way.
Old Dec 26, 2022 | 09:44 PM
  #135
greg8453's Avatar
I remove whatever is needed to expose it well. That turbo would be off if I were doing this job.
Old Dec 27, 2022 | 09:49 AM
  #136
any suggestions on where to get started taking the turbo off? It's very hard to get to or see anything. I can only see the 4 bolts to the right if the turbo from the top of the engine bay.
It's an automatic and I've read they are a bit harder to work on
Old Dec 27, 2022 | 10:39 AM
  #137
I took the turbo off on my 5-speed car. What a PITA. Even broke off a stud into the exhaust manifold, so had to take that off, too, and take it to a welding shop to remove the broken stud.
Can't be that hard to get the thermostat housing off.
Old Dec 27, 2022 | 10:53 AM
  #138
Well I could probably get to the inside bolt with some sort of swivel. But it might be nearly impossible to get it back in. There isn't much room between the thing to the right of the turbo and the bolt.
Old Dec 27, 2022 | 11:31 AM
  #139
That bolt behind the coolant temperature sensor, to get at it you must remove the sensor, use a 19mm deep socket, like for your lug nuts.
Old Dec 27, 2022 | 12:32 PM
  #140
Just looking at mine, it looks like the heater hoses are what's most in the way.
