Coolant leak somewhere
Old Dec 30, 2022 | 07:32 PM
  #151
hhrumadbruh's Avatar
I managed to get to the 10mm bolts on the thermostat housing. Had to remove the right side pipe. I can see why people hate working on these cars and why labor costs are so extreme. I wouldn't do this for anything else for less than $500 lol
Old Dec 30, 2022 | 09:51 PM
  #152
Ok I've narrowed it down to this thing. Anyone know what this is? Does it need to be adjusted if I remove it?
Old Dec 30, 2022 | 10:14 PM
  #153
Not sure how but I've managed to wiggle it out.
Not fun but it was rewarding.
Here are some pics.
Old Dec 31, 2022 | 07:23 AM
  #154
A crusty looking water pump! Now clean the mounting surfaces and put new orings in place and install the new water pump,
Old Dec 31, 2022 | 09:52 AM
  #155
Can I re-use the outer cover? All that orange stuff scraped off.
Old Dec 31, 2022 | 10:08 AM
  #156
Looks like the pump was previously replaced by someone that doesn't trust rubber O-rings for sealers. The previous owner did not believe in changing oil or using the proper synthetic oil. Synthetic oil leaves a brown/orange color on the metal not black.
What "outer cover"? If it is metal and not bent reuse it.
Old Dec 31, 2022 | 10:18 AM
  #157
I don't know the proper name. Its the half shell that faces the driver side that holds the 2" silver pipe. It has 4 or 5 10mm bolts that holds it into the actual water pump. And it has the drain bolt on it.
Old Dec 31, 2022 | 10:35 AM
  #158
Yes you can reuse that, clean it well and use a new gasket
Old Jan 1, 2023 | 01:30 PM
  #159
Happy new year everyone!
How does this look?
Old Jan 1, 2023 | 02:17 PM
  #160
Nice! You have a good helper there!
