Coolant leak somewhere
Old Jan 1, 2023 | 02:31 PM
  #161
hhrumadbruh's Avatar
3 actually!
Got the waterpump back on. Got new o-rings on the silver pipe thing going to it.
Got both ends connected. Just have to push the thermostat block back enough to bolt it up.
I forgot what bolts went where...there is one longer...anyone know where the longer bolt goes?
Old Jan 1, 2023 | 02:34 PM
  #162
Assuming the bottom bolt is the longer bolt?
Old Jan 1, 2023 | 03:58 PM
  #163
Yes, longer bolt in the deeper hole. You torqued the 3 sprocket bolts first before you put the balance shaft chain on ?
Old Jan 1, 2023 | 03:59 PM
  #164
I doubt it would fit in any other. Give it a try.
Old Jan 1, 2023 | 04:02 PM
  #165
Haven't got there yet.
Just finished the 3 thermostat housing bolts. Any idea what torque they need? I just did them by hand for now. Hopefully not too much.
Old Jan 1, 2023 | 04:03 PM
  #166
89 inch lbs
Old Jan 1, 2023 | 04:35 PM
  #167
Most of the small bolts and nuts are 89 lb in
Old Jan 1, 2023 | 06:11 PM
  #168
The 4 water pump bolts are 18 ft lbs
look in our how to threads there is a torque spec thread in there.
Old Jan 1, 2023 | 07:26 PM
  #169
Ft lbs or inch lbs for the thermostat housing?? We have a craftsman that goes down to 20 or theoretically 10...
Old Jan 1, 2023 | 07:37 PM
  #170
Inch pounds. Typically torque wrenches aren't very accurate at their lower limits like that. You can get an inch lb torque wrench for under $20 at Harbor freight.
