Coolant leak somewhere
Old Jan 1, 2023 | 07:44 PM
  #171
greg8453's Avatar
A true inch pound torque wrench will be a 1/4" drive and they are accurate.
Old Jan 1, 2023 | 07:45 PM
  #172
greg8453's Avatar
Originally Posted by hhrumadbruh
Ft lbs or inch lbs for the thermostat housing?? We have a craftsman that goes down to 20 or theoretically 10...
Don't use that for any inch pound bolt.
Old Jan 1, 2023 | 07:56 PM
  #173
hhrumadbruh's Avatar
Got it. I wont.
Any suggestions on a decent digital inch lbs torque wrench? Don't see anything in stock locally so I'll just have to order it. Heading to home depot and Lowe's now just to double check. Ace and harbor freight just closed.
Old Jan 1, 2023 | 08:20 PM
  #174
Old Jan 1, 2023 | 09:11 PM
  #175
Good thing I have a ton of 1/4 sockets already!
Old Jan 1, 2023 | 09:41 PM
  #176
The only place I would worry about inch lb is the pan, those will warp the sheet metal if too tight. Anything smaller than 13mm just get firmly tight.
I stand corrected, blame pre coffee brain.; 89 INCH pounds, that is slightly past finger tight by about a quarter to half turn.
Torque specs are for things like head bolts and critical things that need to be evenly or consistently tightened. The ones with a torque plus angle are critical.
See if you can find a torque wrench that has ever been used in a mechanic's tool box.
Old Jan 1, 2023 | 10:34 PM
  #177
I would rather do everything legit. Except for the flex pipe bolts. I put 330 ft lbs to those. Took more than that to get off.
I got the turbo exhaust exit on. O2 sensor. Manifold cover. Thermostat. Re insterted passenger side hose on thermostat.
Now it's time for the water pump..
anyone know which bolts go where?
Old Jan 2, 2023 | 07:15 AM
  #178
The long one from the front above the front cover, the 2 shorter bolts in from the transmission side on the back of the water pump. Save the last for after you install the front cover.
Here’s the dimensions of those bolts
Old Jan 2, 2023 | 07:44 AM
  #179
Thank you!
Old Jan 2, 2023 | 08:31 AM
  #180
I did post that DDM tutorial about VVT Ecotec assembly, loads of information in that.
