Coolant leak somewhere
Old Jan 5, 2023 | 06:49 PM
  #211
I’ve had to install a tensioner already activated, it’s still working just fine.
yes, I now remember those spacers are between the sprocket and the harmonic balancer, on the 2.0 LNF only.
Old Jan 5, 2023 | 08:31 PM
  #212
hhrumadbruh's Avatar
Forgot to tighten the thermostat housing banjo bolt lol. Bunch of coolant leaked out. But its fine now. I guess it was just the water pump.
Old Jan 5, 2023 | 08:46 PM
  #213
Forgot this thing...where does it go?
Old Jan 6, 2023 | 07:50 AM
  #214
If it’s green plastic, the recycling bin, that’s the protective disc from the harmonic balancer seal installed in the front cover
Old Jan 6, 2023 | 10:26 AM
  #215
#900 shows the shim behind the sprocket, like Oldblue said
Old Jan 6, 2023 | 10:38 AM
  #216
Check out the conversation over here for more info
https://www.chevyhhr.net/forums/2-4l...16/#post933575
Old Jan 6, 2023 | 12:14 PM
  #217
Photo of LNF 2.0 timing chain sprocket, now shims
Same engine
Old Jan 6, 2023 | 05:27 PM
  #218
They're so thin, it doesn't seem like it would make a difference, but...
The slight misalignment of the crankshaft gear could potentially cause premature wear, the smart move would be to put them where they belong.
Old Jan 6, 2023 | 10:45 PM
  #219
Im sorry but i can't see those pics or they don't enlarge for me to see anything in detail.
is the right place in front or behind the timing sprocket?
Old Jan 6, 2023 | 11:10 PM
  #220
FireManGeorge gave a link in the other thread. 1 in front and 1 behind.
