Log In
View Full Version : Audio and Video
Pages : 1 [2] 3 4 5 6 7 8 9
  1. Radio does not work
  2. Starting my stereo upgrade.
  3. Pioneer Stereo Headunit Replacement
  4. Powered Sub install
  5. Head Unit and/or Speaker replacement
  6. Crackling noise
  7. Radio seems inop after dead battery
  8. USB drive not being read
  9. Got Hollered At Yesterday by some Teens!
  10. Rear speaker cutting in and out
  11. How to sort music on a USB drive for the factory stereo system
  12. 2011 HHR stereo question
  13. Installing a Pioneer GPS Receiver, what to expect?
  14. Speakers randomly go in and out, in groups
  15. How to sort your music on a USB drive for a GM factory radio
  16. ID3 data not showing up correctly
  17. USB drive
  18. OEM subwoofer
  19. 2011 HHR 1LT(we think) XM options
  20. Amp install now buzzing ???
  21. Can you use factory/onstar mic for aftermarket unit?
  22. Witch wiring harness is correct for me
  23. Antenna mount and antenna
  24. 2011 non Premier Stereo
  25. Wiring diagram?
  26. Radio problem (not speakers!)
  27. My new favorite USB flash drive for radio
  28. Should I seal my doors?
  29. 06 HHR Premium Amp found missing
  30. Water damage to the radio
  31. can't Vin unlock radio
  32. NO sound from Radio
  33. Reinstall take 2
  34. trying the find the right wire hardness
  35. Backup camera using running light power
  36. 2009 Audio Questions
  37. 2008 hhr
  38. How to wire Kinivo BTC450
  39. Radio frequency
  40. Radio console is no longer playing in stereo
  41. Tapping into speaker wires under the drivers carpet
  42. USB radio question
  43. What are the OHM's on the Front speakers ?
  44. Another audio upgrade ?
  45. Speaker question
  46. hhr radio replacement
  47. New radio with nav and rear camera
  48. Anyone know the RMS power in 09 HHR LS factory radio?
  49. Connecting Samsung Galaxy s4 to 2009 HHR
  50. iSimple Connect ISGM652
  51. They said it wouldn't fit!
  52. Replace speakers
  53. Whining noise heard through stereo.. PA system whining through PA speaker.
  54. Vehicle disable via OBD II?
  55. Speaker failure
  56. Speaker recommendation
  57. GROM Audio for HHR?
  58. Oem radio question
  59. Easiest, no-sub, way to install an amp? Do I even need an amp?
  60. Re-wiring Frontdoor Speakers/Tweeters
  61. Stock Subwoofer Specifications
  62. message on radio AUX INPUT DEVICE
  63. Anybody installing a new Head Unit presently
  64. Kenwood DPX500BT Owners
  65. wanting change radio
  66. Color of wires for pin numbers.
  67. Looking for advice on adaptor
  68. Maybe replacing Door speakers, but should I worry about A-piller tweeters?
  69. CB radio install
  70. xm question
  71. Factory 7 Speaker Pioneer System
  72. Head Unit Compatible with Existing XM
  73. Speakers go in and out
  74. HD Radio
  75. Stubby antenna question...
  76. radio quit working
  77. aftermarket radio
  78. speakers cut out, weak antenna
  79. Do I have xm radio and I just don't know it
  80. Sound System works when it wants too!
  81. Radio buttons
  82. Input changes when I hit a bump
  83. Speakers not working sometimes.
  84. Asteroid (android) Head Unit install
  85. what makes the stereo loud?
  86. White noise from all loudspeakers
  87. wanting xm in my car
  88. Stereo speaker problems
  89. C2r-gm11 - 2009 hhr?
  90. HU install thread
  91. OnStar 2G support ending - handsfree options.
  92. pairing my phone 09 hhr
  93. Buying a stubby antenna
  94. Instrument lights on continuously?
  95. My Factory Stereo LED Burned Out - Help?
  96. stock stereo
  97. Are 4 door speakers standard in all HHR's?
  98. Radio/speakers issue
  99. Audio competitor having voltage ISSUES :(
  100. More XM Confusion
  101. How long is the alt-to-battery 4awg?
  102. Harbor Freight horns: anyone used them?
  103. Has anyone looked into this
  104. Model car switch box?
  105. Will Kicker 6 3/4 Replacement speakers fit?
  106. pop in system when opening and closing doors
  107. Wife's SS Pioneer System: Install Speaker Upgrade, Door Deadening
  108. What am I doing wrong?
  109. Adding a sub to the factory base radio
  110. PAL Software Upgrade
  111. can I fit a parrot ck3000 in an HHR?
  112. Upgrading questions...
  113. Antenna options for better reception?
  114. Low audio in Rain or Fog
  115. Please Help!!!!!
  116. RIght side door speakers in and out, now completely out
  117. Got my system installed finally!
  118. Can I use the fusebox empty slots for other things?
  119. Cheap and easy door speaker replace tutorial w/ repurpose hack & pics
  120. Very local radio reception only
  121. Bluetooth issue
  122. DVD Player?
  123. 2007 HHR stereo upgrade
  124. 2 stock batteries...how to vent both?
  125. Sirius adaptor for stock radio w, premium (pioneer) sound
  126. Multimedia Entertainment Unit and Interior Mod. 2006 HHR
  127. Head unit install troubleshooting
  128. Factory sub
  129. 2009 panel stereo install thread *pics*
  130. Help trying to install headunit
  131. Got a 18" sub today
  132. Using your stock door speaker adapters
  133. Oddness after installing a new stereo
  134. Blowing a woofer! On Purpose!
  135. Play Ipod Touch Music Via Bluetooth
  136. New speakers
  137. adding bluetooth
  138. Head Unit Replacement Advice!
  139. Adding a second battery - few Q's
  140. Stock sub help
  141. Bass goes down when i turn volume up
  142. 2006 HHR SQ build Focal-Pioneer-Alpine
  143. Focal speakers
  144. Shallow mount subs
  145. Use existing XM antennae
  146. Double Din Install in My HHR Panel
  147. stock 8" sub box/sub input needed
  148. Rear stock speakers not working - where to start?
  149. Added stock subwoofer and amp to LS Panel
  150. Need some stereo gurus
  151. UUI radio (with USB port)
  152. Adding USB power port in dash-top compartment?
  153. Gmos-lan-03
  154. AGM replacement battery?
  155. Stock radio and smart phone question
  156. Am I getting old maybe?
  157. radio pushbutton paint worn off; decals?
  158. sub/speaker combo with amps
  159. New sound system
  160. Dash kit options for double din
  161. 4 main speakers are dead
  162. 2010 HHR LT non-premium wire pinout?
  163. New to stereo install stuff, please help.
  164. Aftermarket deck install
  165. Alpine INA-W900 Double DIN with NAV
  166. GM/OEM Stock Navigation fitment question
  167. sub questions..
  168. Original sound system wiring
  169. Question regarding car horn
  170. No speaker adapters needed!!
  171. Radio help
  172. Factory Door Grommet ??
  173. Amp rack wires routed better
  174. Speakers do not always work... Help!!!
  175. FM reception goes out in specific places
  176. 2011 Radio Quality?
  177. Double Din Touch Screen install help & advice
  178. hhr 2007 head replacement need help!!!
  179. Would "MyLink" work with HHR
  180. Plug in wiring adapter Chevy HHR LS
  181. 06 Power Amp
  182. bluetooth?
  183. PAL - vs - USB Youtube videos
  184. amp suggestions
  185. Personal Audio Link for 2011 HHR LT?
  186. Bluetooth vcim module
  187. No FM Frequencies?!?
  188. Need suggestions on routing sub wires
  189. add amps and EQ's to existing system
  190. Excessive audio (MS8 Imprint)
  191. Antennas ?? Which is Which
  192. Front speakers, tweeters not working 08 SS
  193. How to power the antenna for my car pc?
  194. 2010 upgrade
  195. Has GM taken any action on HHR speaker problems
  196. Non-best buy/frys brand gear thread!
  197. wanted: pioneer factory amplier
  198. Tweeter question
  199. new bumps
  200. Popping sound heard in speakers when i come off brake pedal
  201. Another member using Pioneer!
  202. High End Audio Install
  203. Having some trouble with dimmer and console lights after radio install
  204. Updated HHR: Alpine, Kicker, Pioneer
  205. What is everyone's stock battery's resting voltage?
  206. 2006 LT- stock CD player skipping
  207. factory sub upgrade to a 10"
  208. Posted this in mods/interior. Maybe it's better here? need rocker switches mounted
  209. cargo speaker wiring
  210. Stock Radio Faceplate
  211. Wireless Backup Camera Add.....Neat
  212. New Stereo Head Unit - Ignition Wire?
  213. Upgrading Pioneer component ?'s
  214. Video Playback Strangeness
  215. double din bracket for the storage area
  216. Audio/Video Suggestions (Help Please!)
  217. Newbie with some audio hints needed.
  218. Two Front Door Speakers Question
  219. What to install In-dash Nav
  220. Predictor scanning light alarm...
  221. GPS System for 2011 HHR 2LT
  222. intermitten speaker
  223. Is Dealer Programming Required?
  224. 2006 HHR LT - Sound System weak - NOT fuses?
  225. stock unit + line out converter to a crossover, to 2 amps...?
  226. Most wattage you can get from stock electrical?
  227. A couple of questions
  228. HHR 2LT Sounds System Upgrade - Pictures
  229. Another dead radio
  230. Stereo questions...
  231. 2007 blank radio display
  232. Help
  233. Any1 got pics of how u ran ur RCA'S from deck to amp?
  234. Sub replacement - 2ohm/4ohm?
  235. Sub box needs a home
  236. Removing a stock radio
  237. Anyone good with sub box design?
  238. Alpine fitment
  239. 2009 hhr
  240. Stock wiring pinout?
  241. USB radio in a 2008 with pioneer system?
  242. 3 Q's
  243. Bass knob location ideas?
  244. Tablet Install Pt 2
  245. Dash Waterfall Panel Won't Re-Attach
  246. Replacement Door Speakers 10' HHR Base Model
  247. the down low
  248. iPhone Siri and Stock Radio + New Head Unit Suggestions
  249. Car sat for a while. .now pass hid wont work
  250. cobalt amp/sub
