Log In
View Full Version : Audio and Video
Pages : 1 2 3 4 5 6 [7] 8 9
  1. ADDING XM to your Factory radio update
  2. Xm Radio Solution for all
  3. Another XM Question
  4. Hooking up a better sub: Question on Line level/output converters!
  5. Pioneer Z2 Installation.
  6. Another Victim
  7. stock HHR speakers
  8. MP3 playing in LS
  9. Proper lighting for the window switches
  10. HHR Speakers
  11. Harness nightmare
  12. Amp cuts out
  13. XM question
  14. Sirius Ragio for HHR
  15. Will these LCD Headrests Fit?
  16. First Post - upgrade question
  17. Scosche harness
  18. Mounting Depth In Rear Panel For Subwoofers
  19. Need help finding Pioneer cover p/n?
  20. xm feature in 06 hhr ls
  21. New door speaker question
  22. RE: Audio steering wheel buttons
  23. Alarm recommendations
  24. 12 volt outlet
  25. Grounding
  26. Altenator Whine with XM Playback
  27. XM/ID3/CD-Text data is cut off instead of scrolled.
  28. Trying to subscribe to XM radio,need help.
  29. HHR Speakers
  30. Kick panel sub
  31. Help! How to change door speakers
  32. Alternator---how many amps?
  33. stereo wiring help
  34. Subwoofer Volume Control Install
  35. Amp and 10 inch sub install
  36. Coming soon...Sirius Backseat TV
  37. Overhead DVD & Headliner Install
  38. Dome light wires
  39. power supply polarity
  40. Are door speakers different?
  41. DVD player
  42. Line level output converter
  43. Sirius for 2007 HHR is here!
  44. Added Boost???!
  45. Subwoofer cover panel, Help!
  46. First Post!
  47. speaker wires
  48. Pioneer AVIC D3 in HHR?
  49. stereo install
  50. 8" sub enclosure
  51. stock radio without xm
  52. I'm more likely to NOT go the "enhance the stock system route "
  53. How to hook up an amp and sub-woofer setup without affecting the existing Premium sys
  54. sub box
  55. I Want A Sub Wooofer
  56. Anyone having problems with stock radio
  57. Returning to stock?????
  58. AMP upgrade
  59. Factory sub
  60. can someone help me understand these terms
  61. Speaker Installation Issues...
  62. Sound upgrade.
  63. So confused by my radio wiring...
  64. Bazooka
  65. stuffs goin in tonight, (hu) what color am i lookn for?
  66. grounding issue
  67. PAL compatibility with new iPods?
  68. I Was Gettin Some Head!
  69. AUX input
  70. Alpine Nav
  71. Audio smart? HELP!
  72. Ground loop on AUX input
  73. Alarm sounds
  74. AM Radio Diffculty
  75. Stereo systems
  76. Good door speakers?
  77. runnin dual batts?
  78. XM kit for Factory Radio.
  79. Preout levels
  80. ON STAR Whos using it and what do think about it
  81. Quiclk advice needed
  82. XM Radio upgrading their sound quality
  83. Which socket for sub box?
  84. Wiring disaster-help needed
  85. Any Audiophiles
  86. Pioneer AVIC D3 in HHR?
  87. Does anyone know spaker sizes in HHRs
  88. Express window up?
  89. Would this work???
  90. GM Personal Audio Link iPod review on Youtube
  91. Installing Factory Sub unit with Box into 07HHR with no sub...
  92. Anyone else have this stereo problem...
  93. Fan
  94. Better factory Pioneer speaker performance with cargo floor in "upper" position?
  95. Amp/Sub Install Power Problem
  96. How to lock nav disc in the pioneer avic d2
  97. Audio Wiring
  98. Compact powered subs w/stock HU?
  99. Pre-Out Voltage
  100. Factory rca outputs
  101. Adding Subs to the Panel
  102. Will factory prem. deck be enough to push better door speakers?
  103. where is my amp???
  104. Help request with Amp install.
  105. Aftermarket navigation in your HHR?
  106. 07 to 06 stereo swap?
  107. Aftermarket headunit with Pioneer speaker option.
  108. WTB factory sub box
  109. I have a question or two
  110. Speaker Installation
  111. Box building?
  112. My GPS solution
  113. Getting XM started??
  114. How to Connect to Factory HU
  115. Speaker & Amp pre-setup questions
  116. Need Options for Rear Speaker Compartment!
  117. Stereo Install
  118. Optima batteries
  119. Need to replace subs....any thoughts about this?
  120. look 4 a DVD Player
  121. Factory LS Amp
  122. A sub question
  123. TLC Rides HHR
  124. Question: Capacitor
  125. Ok, let's say I take out the stock radio...
  126. Adding XM to Premium audio?
  127. DVD Burner?
  128. which GMOS LAN
  129. Found a carputer site for ya.
  130. Backup camera setup for the HHR? Anyone
  131. amp hook up
  132. Sub install questions... help my obi won
  133. My Indash Navigation
  134. NG's Audio Revisited...
  135. upgrade to factory 6 disc
  136. hnewagn's Sub Box
  137. hhr 7 premium pioneer speakers 260 watts
  138. I want this stereo
  139. Wifey Knows Best... lol
  140. Ipod Bracket
  141. Stock sub woofer removal????
  142. CleanSweep
  143. What happened to the PAL?
  144. Kicker 8" CRV install in the stock box
  145. HHR Factory Radio Upgrade
  146. Pioneer Amplifier Adjustments
  147. Antennas
  148. What am I missing on setting stations?
  149. MP3 ID3 Data "Stuck" in my Radio
  150. XM using factory head unit now available
  151. XM Installation
  152. Factory Stereo Question
  153. I need help (stereo)
  154. HELP!!! Amp delimma
  155. I got next
  156. difference between the lan4 and the lan3
  157. Sub wiring question
  158. Pioneer Amp Location?
  159. Do it yourself Sub Box Plans
  160. some small details
  161. RF Shallow Subs
  162. in dash dvd
  163. Aux output
  164. Mitzkity gets lighted
  165. Rear Door Speaker Brackets
  166. Question on Pre-amp inputs
  167. frustrated...
  168. Stock LT sound system
  169. OEM DVD Radio
  170. upgrading low stock radio from 06 to mid stock
  171. Question on the factory sub box...
  172. Here's a dumb question
  173. Aftermarket radio
  174. Mod chip for new Deck????
  175. Alternator noise, have read all posts
  176. My new In-Dash DVD w/ pic!
  177. Want to install a new stereo system
  178. Added some Flat Screens for the kids!
  179. Amp popping
  180. MP3 hook up?
  181. Difference in radios
  182. Sound system upgrade
  183. I might be a lil retard? please help
  184. Im Buying Scosche SLC4
  185. How can I make the 12V outlet switchable with the ACC?
  186. Hd Radio?
  187. Factory remote wire?
  188. tsb on poor fm reception
  189. Sirius installation: where to put it?
  190. technical question
  191. Speaker whining
  192. Updated pics of my new JL Audio system...
  193. How to remove doors for speaker install... anyone know?
  194. LEDs OK to install??
  195. Placing a sub in the stock hole on an LS.
  196. Breaking! XM, Sirius Announce Merger!
  197. Boredom is AZ
  198. Factory volume?
  199. audio control on steering wheel
  200. Powered subwoofer and Premium System
  201. People with pioneer headunits...
  202. Sub enclosure??
  203. What size capacitor??
  204. Dynomatt/ Hushmat
  205. stock radio possessed
  206. XM radio
  207. New JL Audio products for 2007 !
  208. Some current pics, possible new system pics...
  209. List Your 8" Sub !!
  210. Installing a Dedicated Amp for a Repl. 8" Sub
  211. Ultimate stereo for the HHR
  212. sub wiring
  213. Wiring Questions!
  214. Aftermarket radio help!!!!!
  215. Start of System
  216. Six Disc CD Changer
  217. New way to install my Performance Timer
  218. XM Sirius question ?
  219. HU Harness news?
  220. Best Place to wire in rca for subs
  221. New Years project
  222. Old Kicker Subs
  223. Lessons Learned: How To install a new 8" sub
  224. Lessons Learned: Steering Wheel Controls
  225. Lessons Learned: Using GMLAN adapter with aftermarket radio
  226. 06 Chevy HHR alternator/power ?'s Can my car handle the system? PLEASE HELP!!!!
  227. Last song restarts, sometimes
  228. I need a wire diagram
  229. VSS speed scensor
  230. Using the equalizer
  231. I-pod Interface From GM
  232. Alternator Feedback
  233. iPod sound quality Aux input vs FM transmitter
  234. ipod question
  235. 2006 CHEVY HHR iPOD DIRECT INPUT
  236. Turning Subwoofers on and off.
  237. DVD Headrest Monitors are installed!
  238. Satilite radio
  239. New media player
  240. Rear Parking Sensors Installed
  241. XM location
  242. ipod connector release date?
  243. Sub boxes
  244. Video System questions?
  245. Rear door speakers
  246. Dimmer Switch
  247. New speaker wires
  248. What do you guys think?
  249. Stock amplifier wiring chart
  250. Stock amplifier wiring chart
