Log In
View Full Version : Audio and Video
Pages : 1 2 3 4 [5] 6 7 8 9
  1. system for my 08 panel
  2. 2006 HHR LT2 - want to add XM
  3. Where is the On-Star module hiding and how do I get to it?
  4. Question on the XM Module
  5. rear antenna
  6. Keyless Entry Pad
  7. Sub speaker
  8. I think I blew the sub!
  9. Steering Wheel Radio Controls...Should I Do It?
  10. In-Dash iPod radio?
  11. Will PAC AOEM-GM1416a work on 2009?
  12. Little idea
  13. rebuilding for 2010 season
  14. Stock Radio Specs?
  15. Anyone Ever see this ...
  16. Backup Video
  17. Rear door speakers not working?
  18. PAL Personal Audio Link
  19. How to setup your Bluetooth phone w/o using Onstar
  20. Want to replace stereo w/premium system
  21. Need Help!!! Factory amp hookup install??
  22. Sirius Connect compatibility w/factory radio
  23. GPS Location
  24. the right sub boxes
  25. Power wire dilemma
  26. What are my chances on blowing my sub?
  27. Nav system installed
  28. Factory 7-speaker system question
  29. Getting ready for 12s
  30. Alpine iXA-W404
  31. Butt Kickers
  32. aftermarket radio compatibilty
  33. getting rid of upgraded pioneer system
  34. Look to swap to aftermarket 2DIN multimedia head unit
  35. o2 audio speaker fitment questions
  36. Got a new toy! GoPro Wide video camera
  37. Subwoofers and Door Speakers!!!
  38. AWESOME Deal on a headunit...
  39. where there any changes from 2008 to 2009 in the sound system?
  40. Ready to replace stereo but afraid of BCM issues
  41. Aftermarket Radio Adapter???
  42. is there a remote wire?
  43. My 3rd gen iPod touch not working w/ usb?
  44. Factory Sub insulation opinions
  45. Using a GPS to Find Speed Traps?
  46. Removal of PAL from HHR - Questions
  47. no speakers working on drivers side
  48. oem backup camera
  49. Does this wiring idea sound correct.
  50. Door Chime Sounds!
  51. need some help with install
  52. Looking for some info before I dive in
  53. MP3 File and USB File type of question
  54. Can Pioneer Premium Sound by added
  55. stereo kit from crutchfield????
  56. Gm pal not worth a dime
  57. installed new speakers
  58. GM's navigation unit
  59. Pioneer AVIC-F500BT Stealth Install
  60. Swapping Pioneer premium HU
  61. no sound..
  62. Pop or snap from radio
  63. 2009 HHR with Axxess XIA-D01?
  64. Usb port
  65. XM for $88 a Year (or for your second year)
  66. Bought a HHR sub and amp.
  67. Got my steering wheel radio controls!
  68. Sub Box
  69. What adapters do i need
  70. DVD headrest question?
  71. what do i need
  72. Line Out Converter
  73. Aftermarket Tweeter Installs
  74. Kappa One - Install Help Needed
  75. Interior Trim Buzz (Specifically, passenger door)
  76. choosing right harness
  77. Bluetooth for 06-07 HHR's with onstar!!!!!
  78. Install Help
  79. 08 HHR radio swap.
  80. Adding a amp + sub
  81. Battery Post
  82. OEM Radio aftermarket bluetooth integration
  83. Wiring Harness Needed
  84. Device connect fail message
  85. Passport SR7
  86. 09 2LT Radio fade front to back
  87. Picking up power steering noises on all AM radio stations only
  88. USB Fail
  89. Aftermarket HU, Amp, Spkrs. - Stock Spkr wire.
  90. 2LT Sub-woofer control?
  91. Component Speakers for Front Doors - How to patch into stock wiring...
  92. installing steering wheel radio controls
  93. Pioneer/bose
  94. Power circuit
  95. Auto shut off for radio?
  96. Help: Using an extra fog light switch
  97. Quick Question
  98. Alternator whine
  99. Satellite radio question
  100. Removing Head Unit
  101. speaker adapter ?
  102. OEM Stereo Upgrade
  103. HHR Remote Start
  104. anyone know how to take the antenna off?
  105. USB Interface Stereos
  106. 2009 us9 radio w/USB in a 2008?
  107. can you disable auto door lock when putting car in drive?
  108. does anyone know where the door lock relay is located?
  109. Radio Didn't Come On
  110. Onstar Lock Pick for Bluetooth
  111. speed sensor wire ?
  112. Opinons on PAL
  113. Stock Speaker/Amp question
  114. 2009 Premium HU?
  115. Poor tuning?
  116. I pod connection
  117. Door Chimes and Blinkers
  118. Navagation
  119. Pioneer Head Unit Model Number?
  120. is it possible to add on-star?
  121. Sub Woofer Volume Control
  122. iPhone 3Gs not compatible...?
  123. I am looking at a new h.u.
  124. Dead Radio/Door Chime
  125. Replaced front door Pioneer with Focal
  126. Stock amplifier Wiring
  127. Turn Signal Audio
  128. Help on replacing premium system
  129. Contiplating on putting in a couple of 10's
  130. Wiring Diagram
  131. iPod hook-up
  132. 09 amp wiring diagram ?
  133. aftermarket double din wiring harness 09?
  134. anybody Pioneer avh p4000
  135. Stock speaker size
  136. speed signal,reverse signal
  137. Taking out Factory Amp...
  138. steering wheel controls- where do the wires go?
  139. will this fit into the stock sub box
  140. Roof flex
  141. SS with USB port, Ipod not supported???
  142. Installed a sub, things aren't working now!
  143. 08 HHR Build log.
  144. radio not working
  145. Bluetooth setup ?
  146. What harness do i need?
  147. Auto dimming mirror and radar detector
  148. wire harness
  149. cd player trouble only when its cold out ???
  150. 2008 xm upgrade
  151. Placement of 10" Bazooka Sub - Parallel or Perpendicular?
  152. Questions about alarms and the HHR.
  153. Sound Proofing
  154. Help with XM radio
  155. How to not fix a radio programming problem
  156. Deck Problems
  157. 07 Radio install
  158. can i hook up subs and amp to my stock 2006 hhr radio?
  159. Anyone install HD Radio?
  160. New Plastics for Stock Radio
  161. Bluetooth/USB Stereo system
  162. Pioneer AVIC-F90BT
  163. Radio issue..stays lit
  164. Fresh email from GM: Your XM is on now.
  165. Has anyone installed soundproofing in their HHR?
  166. Good audio article
  167. Anyone seen this?
  168. Stock Subwoofer Location
  169. Radio issue
  170. Stock HU Unlock Question (Dealer guys?)
  171. Motorized in-dash DVD without covering vents
  172. push button start
  173. What do I need to upgrade radio to bluetooth?
  174. Drive Play install/wiring help
  175. Installation instructions
  176. still skipping stations
  177. Tailgate speaker mount
  178. Bass rattle
  179. Tapping front speaker wires
  180. aftermarket cd player???
  181. Shallow Mount Subs
  182. Questions about the Stock Radio
  183. aftermarket HU install
  184. "Train Horn"
  185. gps nav locked up
  186. Where do you have your GPS mounted?
  187. car stereo troubleshooting
  188. Replacing 08 Delco system with an 09 system.
  189. Replacing factory head unit
  190. Team sponsorship
  191. Broken antenna cable
  192. my system
  193. In need of the right Radio Harness 2006 HHR
  194. Truckin' magazine
  195. Gps nav ?
  196. 2009 LT -Sony Deck, JBL Sub(refinished box!) and AMP, Garmin GPS transplant complete!
  197. FM static on startup
  198. Sound Deadening
  199. Adding XM Radio to a 2008
  200. what a pita but its finished
  201. Hi I'm New/Need Audio Advice!
  202. chevy pal system
  203. How much would you spend?
  204. how to hook up Rca's with stock stereo
  205. OnStar GPS
  206. what is the best ground in the rear of the car.
  207. 2009 HHR - Harness Adapters 'n' stuff
  208. Ignition for radio?
  209. crutchfield referral code
  210. New amp!!!
  211. Free sub box plans
  212. gettin ready for next season
  213. updating install for new season
  214. Back Up Camera??
  215. Too many plugs.... :( im tired
  216. Tire Pressure Sensors
  217. gain on factory amp...
  218. 08 World Finals Install
  219. usb problems
  220. 12" L7 Install/Tuning
  221. Figlerglass
  222. PAL for 2007 HHR LS
  223. salvage yard score...questions
  224. Aftermarket sub-woofer popping with power off
  225. Premium Sound system install?
  226. radio dash kit ??????
  227. door speaker polarity wire color
  228. Harness?
  229. 10" Subs In Rear Hatch
  230. broken aux jack
  231. Walkman hookup
  232. Dual 12" Kicker CVR vs. 12" Kicker L7
  233. Antennas and GPS
  234. onstar adapter /? which one??
  235. Kicker CRV or CVT???
  236. Wiring Question
  237. PAL (Personal Audio Link) Problems
  238. Underconstruction ss
  239. Where to catch pink remote wire?
  240. Door speaker depth?
  241. XM Commander radio receiver
  242. SPL Comps, or even SQ Comps
  243. bass processors
  244. Underconstruction
  245. Hi! My Name Is Hector And Im A GM addict!!!
  246. Aftermarket HU install AM/FM warning...
  247. color code
  248. how to bypass onstar
  249. Remote Start Anyone?
  250. '09 with XM delete
