View Full Version : Audio and Video
Pages :
4]
- Upgraded Stock Radio
- Installing aftermarket amps keeping factory functions
- Personal Audio Link Performance
- 2011 Personal Audio Link part number
- 64,000 Question.... 2010 HHR XM Radio Question
- Camaro Shark Fin?
- Eric B Build
- Pioneer Premium Sound
- xm radio
- xm radio
- 08 Cobalt sub in a 2010 hhr?
- XM radio
- Adding bluetooth to 2011 HHR LS
- Removing dash top
- More bass without putting in a box
- Has anyone hardwired a V 1 radar detector....
- Thinking about a plasma plate...
- 2 way or 3 way
- 2006 LS HHR Sub ?'s
- 2006 LT onstar and xm Q's
- Low-N-Louds gettin ready for STC'11 Build
- XM Class Action Suit?
- Front and rear speaker replacement question
- Audio help
- 1st gen iPad with USB-equipped radio WORKS!
- Radio controls on steering wheel
- General antenna question
- Free XM for 2 weeks
- Stock sub replacement
- Gmos-lan-04&03?????
- Easiest Bass increase
- HHR Crutchfield Master Sheet
- Replace factory radio HELP
- Front Door Speaker Replacement
- Adding factory amp and sub
- Radio has a mind of its own!!
- High output alternator for 08 HHR
- Pre-amp signal /OEM Sub amp
- Stock radio question
- Hazard Switch Wiring
- XM question
- Disco HU Display?
- spl numbers
- Pioneer Stage 3 Started
- Back Up Cameras
- Help! I Can't get the iSimple Ipod gateway to work
- Stock amp and subwoofer only?
- Old system
- HHR system build - wall, lots of mids/highs, etc
- will a used sub work
- OG needs schoolin' on headrest monitors
- six disc changer
- XM Radio Display
- HHR icon for aftermarket GPS
- Stuck looking for ideas...
- factory subwoofer
- factory panel toolbox/sub enclosure
- system
- Does This Sound Crazy?
- 2010 HHR needs In-Dash Nav/DVD/Bluetooth
- Amplifier Instal
- Antenna help
- New Sub Box built --- (4) 12's HEHE
- Sony xnv770bt & headrest dvd players
- Audio and Bluetooth
- Want your opinion
- Does my 08 radio have the internal parts required for XM?
- Cruise Control Options
- Remote Start Question
- Remote start antenna location
- Another new radio install question
- head spinning about bluetooth and onstar
- cost of speaker upgrade?
- XM radio is too quiet!
- Loud pop from pass side speaker
- Cost of xm
- 2 way remote
- XM Radio HELP please !
- Thing on window
- Rear Door Component Speakers?
- XM Radio problem
- 09 Radio With Factory USB Port
- radio display
- 06 Radio Question
- door speaker depth...
- The power of the Speakers is from the Head unit or from an amplifier?
- 06 radio
- 6.2" touch, GPS, DVD,.... Ordered today
- Help! Right channel quit working
- sunvisors with monitors, whos got em?
- A Couple Radio Install Questions
- Driver side speakers - intermittent???
- rear bumper reflectors
- Axxess Wiring Harness Question...
- search help?
- Installing new JVC in a car with the pioneer system. Have a few questions.
- Need a little help
- Rear Speakers out
- 2010 HHR Radio
- US8 code radio in a LS?
- HELP PLEASE: Wiring diagram for taillights <<<<<
- best way to tie in a Android to OEM system
- back seat amp?
- new speakers
- gmos-lan-04 with non pioneer and no onstar
- xm radio
- Diagnose Rear Amplifier
- In Dash 7" NAV/DVD/DTV/RADIO/TOUCH
- Flash drive that doesn't work with the stereo
- XM radio
- Pioneer AViC-U310BT Navigation installed
- Radio Replacement
- Rear subwoofer wiring
- Steering Wheel Audio Controls
- xm radio
- Remote Wire - Basic Stereo
- 2009 HHR 2LT Bluetooth Capabilities?
- XM radio promo - Canada
- Is a battery isolator compatible with a 2010 HHR?
- Costar BlueStar 2010
- Audio volume goes down by itself
- Zune not suported ...
- XM just got an earfull!
- Has anyone installed a PC into their HHR?
- No Bass with XM?
- HHR Lap top mount?
- Still for someone That Has Installed a GM Nav./DVD Radio
- I use a Zune ...
- How much power in the standard stereo?
- Stock Radio USB port uses
- DVD Install Options
- Anyone Install a Double Din Nav./DVD in a HHR??
- Silencing the Rear Panels in the HHR
- navi question
- pioneer 4200dvd or avic z120bt nav
- Stereo Problems
- any HHR's with walls?
- does stock cd player have xm???
- installed jl in the doors
- Installing Subwoofer to stock basic head unit
- What head unit have you put in your HHR?
- XM nice offer
- Ballast mounting
- Yet another thread about stock stereos ;-)
- Adding Bluetooth to 2009 LT
- adding my subs to a factory stereo
- Rear sub
- 09 HHR LS OEM Headunit
- running new speaker wire through doors
- Stubby Ant
- Stubby Antennae
- Amp Mounting
- bluetooth and gps in top of dash
- where can i get the usb factory head unit
- mp3 player?
- Need help for system power
- 2 12's build
- Do you need to program the radio if you can use the xm upgrade kit?
- Bluetooth - Parrot MKi9200
- Free XM Expired -- What Happens Next?
- Wiring Diagram for 2008 Panel
- Pioneer sale
- Horn Circuit question
- Tapping into rear speakers?
- ??HHR Audio/Video Buildup - Questions!??
- What is better ported or sealed woofer enclosure?
- change antenna w/t a stubbyone
- Audio Link Question
- 12V switched power?
- CB Radio Antenna location?
- Add messages on factory stereo?
- Upgrading to the BETTER factory radio?
- High Pitched whistle through speakers, engine speed dependent???
- Questions on Installing Subwoofer
- Which Subwoofer box do you think is better
- Rear Speaker install
- How do I know is a 6 disc Stereo
- XM radio
- New Radio Install
- Showing off my woofers
- Apple iOS 4.0 now PAL no longer works
- Subwoofer sound quality
- 2006 HHR Radio Install Kit
- Rear Passenger side rattle
- will gmos lan 01 work in 2010 hhr base stereo?
- popping noise from new nav head unit
- Ebay In Dash 7" 2 DIN NAV systems?
- So-So Sound - Is It The Stereo or the Speakers?
- This is how I run wires
- Dealer installed DVD player
- Factory Amplifier
- Replacement radio is totally dead prior to reflash - is this right?
- hhr ss subwoofer
- Free XM
- GMOS-LAN04 - Radio will not turn off with car!
- cd changer
- 08 Wiring
- fiberglass
- XM Radio
- Add another sub to stock system?
- On-Star
- sub. ?
- XM Readout Data
- HD Radio
- Modifying accessory power plug
- Silent radio
- Stereo Wires
- USB Port in 2010 HHR Not Working
- How to access stereo wires for a dvd head rest monitor
- My budget subwoofer install
- Radio not coming on at all
- Bass/Treble Not Staying Put
- Question for those of you using the LAN04 and an aftermarket amp
- sub in factory location
- All of the goodies are in...
- Help needed - middle of install - poor speaker sound quality
- RMS of pioneer premium factory?
- after marketstereo, how does it affect warranty?
- 12inch subs on stock radio????
- UUI / USB Radio
- factory sub and amp on both sides?
- Alarm (Optional Glass Breakage Detector?)
- Where do I get power????
- Double Din
- Added Carputer replaced Stock Stereo (Stereo Adapter)
- Add Bluetooth, 2009 with wheel control, onstar and USB
- Need Help (Again!) - PAC-TR7 with LAN-04
- What antenna adapter?
- xm radio subscription
- Subs for an AA5?
- What size sub - Upgraded Pioneer system?
- Which radio?
- Sub and speaker question.....
- New Stereo System
- Rear Door Speakers Not Working
- New speakers
- Alpine IVA-W505 Installed - Help Needed
- speakers in back hatch cover
- Hardwire GPS
- Radio Button
- Premium sound / GMOS-LAN-04 Install
- Bad Tweeter?
- Pic Request: Sub/Amp Install in Rear Cargo Area
- Stock HU XM Display Scrolling...
- Need help with wiring harness
- Lite glow music interface
- HHR LT 2006 Audio Display and Tuning Problems
- base stereo system question
- 2008 Panel
- Factory GPS
