Log In
View Full Version : Brakes | Suspension | Shocks | Struts
Pages : 1 2 3 4 5 [6]
  1. Bad Groaning noise on speed bumps
  2. Air Ride Kit For Hhr
  3. Anyone tried these?
  4. Squeaky brakes
  5. Eibach or Goldline?
  6. rear levelers and 20s
  7. 2.5 rear drop?
  8. Lower rear only?
  9. Sway bar Questions
  10. Excited HHR owner
  11. wheel spacers
  12. HHR Panel with Goldlines installed
  13. Eibach's installed!
  14. HHR Panel with Eibach Prolines installed
  15. I ordered Gold Lines today.
  16. Random Question
  17. Rear Disc brakes
  18. KYB struts/shocks
  19. Pursuit G5 Springs
  20. New Springs
  21. Lowering Springs are installed!
  22. Gold Line Discontinues HHR Springs
  23. Which way to lower?
  24. One more in favor of Lowering.
  25. a manual tran. can't tow a trailer????
  26. Where to purchase Goldline Springs in Buffalo
  27. 2nd generation Goldlines???
  28. alignment specs
  29. HHR Panel with Eibach Sportline
  30. Eibach Sportline Springs
  31. Question on Trailer Hitch
  32. Air?
  33. Goldline leveling spring question
  34. Finished Eibach Sportline Springs they fit.
  35. Big brake upgrade/rear conversion??
  36. Eibach Springs same as cobalts???
  37. Got my leveling springs installed
  38. Raising an HHR?
  39. Bump stops
  40. Another Towing Question
  41. towing capabilities / trailer towing package
  42. Shimmy after lowering?
  43. Ground Force Rear Lowering Springs
  44. Front Struts, had to do it.
  45. Finally a few pics w/lowering kit and new grill
  46. part of the lowered crew now haha
  47. price ?? progress swaybar
  48. progress tech swaybar
  49. lowering coils & swaybar combo ?
  50. 2LT vs Goldline
  51. Finally: Koni Shocks...
  52. Highly Recommend Canuck Motorsport Springs
  53. Question about Lowering with 18x8/Eibachs
  54. Can you just?
  55. Lowering My 06 Hhr
  56. Canuck Motorsport Springs
  57. Lsd For Sale
  58. Can this be confirmed
  59. Replacement Shocks
  60. Just got off the phone w GM parts Dept
  61. Just got off the phone w GM parts Dept
  62. Sway Bar Questions???
  63. HHR SS suspension on regular HHR
  64. Lowering Question on 20's
  65. cobalt rotors on HHR
  66. front struts leaking
  67. Poll: Adjustable Coil Over System
  68. 1st generation goldline springs
  69. Has anyone tried the H&R Springs?
  70. New Goldlines
  71. brake problems
  72. These springs any good?
  73. Lowering in Buffalo, NY
  74. The Twins Lowered <g>
  75. Shock/strut upgrade
  76. Question about 20's AND NOT LOWERD
  77. Progress Springs (low and dangerous????)
  78. 20" Combo and Spring Question??
  79. Hope this hasn't been asked before
  80. Caliper to wheel allowable clearance?
  81. need to raise the back an inch
  82. Rear suspension, gas shock absorbers
  83. ok, so who has bagged it?
  84. need some info
  85. Finally Installed my Sway Bar
  86. Just a inch or so
  87. Just a little lower 11/2" or 13/4"
  88. Poor Handling
  89. Wheel help
  90. Progressive OR Linear???
  91. Should the Anti-Sway Bar really be called that..
  92. Eibach Pro Drop kit
  93. spring tech springs, good? bad? ugly?
  94. before and after pics of Gold Line install
  95. Front End Alignment
  96. KW Automotive Adjustable coil over kits
  97. Got PurigeN98
  98. Low profile floor jack, a must have!
  99. Wow 60.00 to good 2 b true
  100. Brake squeal
  101. Struts and shocks?
  102. Lowered
  103. 20's and springs
  104. What, exactly, makes up a "sport tuned suspension"?
  105. I am now in the Land Of The Lowered
  106. Suspension & added weight...
  107. Rubbing?
  108. HeLp pLeAsE
  109. Eibach or Progress?
  110. A few questions for those who have installed the rear sway bar.
  111. I got my Slotted and Crossdrilled rotors today.
  112. Joining the "Land of the Lowered"!!!
  113. Swaybar installed
  114. Sub Sub on Bags
  115. Crossroads
  116. Rear Disc Brakes
  117. Lowering and the warranty
  118. Easy install
  119. Ride quality after lowering
  120. Sindy's Lowing project!
  121. Alignment after Lowering
  122. Coilovers!?!?!?
  123. Off to the West Coast...
  124. How to pics
  125. Spring and Exhaust installation in NJ ???
  126. Disks Brakes
  127. Front Strut Tower Brace
  128. Lowering HHR...Week 1 Update
  129. Lowering/Warranty
  130. Lowering car
  131. Anti-Sway Bars
  132. Do I need to replace the shocks if I lower the car?
  133. Eibach springs
  134. Pics of font and rear brakes
  135. Upcoming Eibach Kit
  136. 2006 HHR Alignment Specs
  137. Any info on weather eibach has a kit out??
  138. camber kits
  139. Lifting!
  140. lowering springs
  141. Lowering?
