PDA
View Full Version : Brakes | Suspension | Shocks | Struts
Pages : 1 2 3 [4] 5 6
  1. Pedder Spring clearance concerns, please advise!
  2. Rear pads on an ss. Can I put a cheap set in?
  3. Jingle Noise
  4. Now a question about springs.
  5. Control arms
  6. New rotors and pads!!
  7. rotor size
  8. rotors and pads
  9. New Powerslot rotors and Hawk ceramic pads
  10. Air Struts
  11. lower lt2
  12. HHR Handling
  13. I need some advice on lowering springs and struts
  14. Increased Ride Height?
  15. Hissing sound from under dash
  16. Should I replace worn OEM with KYB Shocks & Struts
  17. Parking e-brake Adjustment??? Help Please!!
  18. Difference between "Touring" and "Sport" Suspension?
  19. Caliper piston dust boot question
  20. coming soon to an HHR near you...
  21. Rear Brake Squeak
  22. Drop or no drop? Feedback needed plz
  23. Quick Strut
  24. Work Done
  25. alignment
  26. Best sites to reference for everything "how to" brakes
  27. Koni struts for Cobalt..fit the HHR SS?
  28. Some one has changed the intermediate shaft on his way?
  29. Proper Rear Drum Brake Adjustment Procedure
  30. How do you stop? (Brakes)
  31. Multiple suspension/shocks/brakes queries
  32. GMPP rear sway bar
  33. Requesting F&R swaybar information.
  34. Pedders are on!!!
  35. clunking n front end
  36. Best way to level my HHR SS?
  37. front sway bar
  38. clunk in front end
  39. 06 2LT Sport Tuned Suspension
  40. Saab upper strut mount
  41. Need Advice On Front Rotors
  42. Changing the Wheelbearing & Hub Assembly
  43. Rear shock absorbers with different markings.
  44. Bent rear axle! Straighten?
  45. Disc wear
  46. My front end noise
  47. Front End Clunking....Solved!!!
  48. Performance Brake options
  49. HHR Shocks and Struts Question
  50. What blanks did you go with?
  51. Rear springs
  52. Replacing Sway Bar Bushings
  53. Sway bar bushings
  54. brakes & shocks
  55. What size sway bar links?
  56. Front end clunck goes away after a few miles
  57. Over 70k Miles on original Brakes???
  58. Lowering Kits for my HHR.
  59. Brakelab rotors on Ebay?
  60. Quick Struts
  61. Stock Rear Shock Absorbers
  62. Rear sway bar comes w/bushings?
  63. Cobalt/HHR geometrically the same?
  64. Front End Clunking
  65. struts/sway bar
  66. Gold Line springs
  67. Hub assembly vs. Wheel bearing
  68. Rear spring isolators
  69. Ceramic vs. Semi-Metallic Front Pads
  70. My parts are ordered
  71. Cobalt springs ordered... yeah
  72. Front end noise:
  73. EBC Red Stuff pads separating from backing plate
  74. Brake Caliper Decals
  75. Cobalt SS for LS HHR
  76. Shorter shocks...Lower ride..
  77. Brake adjustment
  78. leveling springs..........goin for it.........
  79. cant wait for tomarrow!
  80. New powerstop rotors & EBC pads!
  81. Stop It / Part Deux / Pictures
  82. Rear Sway Bar
  83. sway bar bushings
  84. Uneven Brake Pad wear
  85. Front end clunk
  86. Part # for Energy Suspension sway bar bushings
  87. Powerstop Rotors Powder Coated
  88. Shock - Strut prep info
  89. Alignment
  90. Switched to Goldlines
  91. Wheel LUG striped
  92. looking for gray bagged hhr
  93. Cobalt SS Struts & Shocks in 2006 1LT?
  94. question on the leveling springs.........
  95. Simple Suspension Upgrade 2006 LT
  96. Low and Slow !
  97. Sway Bar Link Question
  98. Front suspension disease
  99. need a brake
  100. Stop It !!!!!
  101. Alignment Cam Bolts..
  102. New Brakes needed?...Maybe not!
  103. getting low soon
  104. Cobalt SS SC front springs
  105. Lowering
  106. Front Sway Bar opinions please
  107. HHRboutique.com for lowering your HHR
  108. Anyone try 205/55/17????
  109. To quick strut or not to quick strut....
  110. big rotors all around?
  111. Replacement Shocks and Struts
  112. Replacing Stock Rear Shocks on UN lowered HHR
  113. rear shocks
  114. Rear Suspension
  115. Suspension Work
  116. clunking noise gone for good
  117. Front strut service life ?
  118. anyone heard of these springs?
  119. E-Brake effort?
  120. springs
  121. Aftermarket bushings?
  122. Adjust parking brake...
  123. Can someone shed light on thr difference in HHr brakes and Cobalt brakes?
  124. Shock/Strut Question
  125. Rattle In Steering Column
  126. eibach lowering spring with 20s will it work
  127. clunking noise
  128. Pulsating brake mystery - one for the experts
  129. progress rear sway bar?
  130. thinking of putting a motor in the truck to tow is that to much weight?
  131. C6 vorvette brakes on hhr???
  132. HHR on Super Swampers
  133. Eibach swaybar
  134. '08 SS stabilizer end links
  135. Cobalt SS Struts?
  136. Brakes....
  137. Lowering springs
  138. Goldline 1st Gen part Number?
  139. Brembo Brakes on a Cobalt??
  140. KYB shocks
  141. rear thuds every bump
  142. All Quiet on the Clunking Front(end)
  143. Brake pedal pulsating!!!
  144. SS Springs/Sway bars
  145. which springs get you the lowest?
  146. Brake shudder - from REAR brake?
  147. Installing Brembo Brakes on a LT
  148. Cutting springs
  149. Chevy camber kit
  150. 13" Viper brake upgrade
  151. Do NOT get your Rotors Turned!
  152. question about airbags..
  153. Best rotors for 06 HHR?
  154. ? on coilovers
  155. No more pulsing pedal or shaky steering wheel. :)
  156. 08 hhr rear drum to disc
  157. LOWERED my '08 Black Panel. Pics.
  158. Rear spring insulator.
  159. SS frt end rattle at 9000 miles
  160. Rear Springs Installed
  161. have rotors turned or go with new rotors?
  162. Anyone tried polyurethane bushings up front?
  163. I want to lower the rear ASAP!
  164. Anyone used (or heard of) Progress springs?
  165. Pulls to the left
  166. Trailer Mounted Dirt Bike Rack
  167. Lowering facilities in Riverside, CA?
  168. Lowering an HHR
  169. H&r springs vs. Eibach
  170. New rear sway bar
  171. horrible screeching from front brakes
  172. Suspension recommendations for 1LT, 1LS, and 2LT HHR's
  173. Lowering recommendations
  174. 2006 HHR lower control arm/ball joint
  175. Cobalt Brake Package?
  176. SS suspension on a 2.4L
  177. Strut nut rusted? Ideas?
  178. Rear Brake Shoe Replacement....Need Help!
  179. Rear Brake Shoe Replacement..need help?
  180. Progress Sway Bar on a 2010 LS?
  181. New Brakes and Rotors!
  182. Front Sway bar bushings
  183. Are Akebono Brake Pad's any good?
  184. Traction Bars
  185. Rear Suspension lift needed
  186. SS brake pad part numbers?
  187. Bolton Rotors?
  188. Front-end clunking
  189. suspension?
  190. To all Pedders gurus
  191. Shorter shocks?
  192. driving in the wind
  193. For those who have had Rotor repairs denied by a dealer
  194. Warped rotors issue - NEED HELP ASAP
  195. OTTP sway bar
  196. Greyghost07 giving a warm shout-out to all
  197. Question before I order Suspension
  198. New Shocks in the back after puting lowering springs..
  199. Getting Some R1 Concepts Possibly
  200. Yellow Springs
  201. sway bar for HHR
  202. Knocking sound from the front end
  203. Sway bar
  204. anyone tried 4.9938.880 eibach
  205. eibach for the ss
  206. Price check on 2008 HHR SS brake job.
  207. Lowering spring install without an impact...possible?
  208. Moog end link grease nipple fittings
  209. 2 gen goldline pics
  210. 30/30/30 rule for newly installed pads and rotors
  211. maint. before lowering?
  212. Best Price on KYB Struts?
  213. part # for brake rotors?
  214. sway bars
  215. Centric brakes... First thoughts
  216. Springs
  217. Pedder springs today
  218. Rear sway bars - SS, Progressive?
  219. Metal clip on front disc brakes
  220. Big Rear Brakes
  221. S10 coil springs
  222. gold line leveling springs feedback
  223. Leaking shock?
  224. Bleeding brakes
  225. 2008 HHR 2LT needs new Front Struts... advice please
  226. suspension nosie
  227. Cobalt Springs?
  228. Leveling – Comments on Cobalt SS Rear Springs
  229. Brakes feel spongy
  230. Lowering HHR
  231. Cut Springs
  232. COBALT SS fe5 shocks and struts
  233. Anybody come out with bigbrakes/rear swap?
  234. Power Slot rotors anyone?
  235. Decided to put new brakes on soon..
  236. new rear shocks.
  237. Torque specs
  238. Sway Bar Link How to??
  239. Lower Control Arm Bushing?
  240. How much weight will it handle?
  241. Rear lowering springs
  242. Springs?
  243. HHR SS Parts
  244. front caliper help
  245. Installed TTR Sway Bar
  246. Pedders springs
  247. GoldLines queeeeestion
  248. Whos car is lowered got pics?
  249. Fe5 shocks and struts
  250. Finally Leveled
