Log In
View Full Version : Brakes | Suspension | Shocks | Struts
Pages : 1 2 [3] 4 5 6
  1. Shock question
  2. Springs Different HHR vs. Cobalt?
  3. Rear Disc Brake Kits?
  4. leaking rear caliper
  5. $30 Shocks vs. $90 Shocks
  6. Brake upgrade Questions.
  7. For those that are curious...
  8. Steering Wheel turning on it's own after starting/killing engine
  9. Got rid of the braking quiver.
  10. Take pity upon my person............
  11. Suspension Advice
  12. Raybestos Quickstruts?
  13. Strut question....
  14. Air Ride Kit
  15. KYB or FE3
  16. LCA Bushings +
  17. 2011 2lt 2.4
  18. Violent shaking while braking, one rotor only
  19. Rear Spring Insulator?
  20. Please help!!!!
  21. Best Sway Bar to use for 2008 HHR
  22. Struts ?? help!!
  23. Coilovers
  24. Clonk sound from the front when I turn
  25. Brembo Hoses and Reflash?
  26. Newbie with some suspension hints needed.
  27. HHR ss lowering???
  28. Spring seats/insulators?
  29. Change Strut Mounts?
  30. Swaybar Question
  31. Speed Bleeders for Non-Brembo SS?
  32. 2008 LS front brake recommendations
  33. Anyone using YYZ V.2 springs?
  34. Air Shocks
  35. Replace Front Brakes 06 LT Best Options?
  36. KYB vs MONROE rear shocks
  37. Will G6 coilovers work on our HHR SS?
  38. Sway Bar
  39. SS springs manual/ auto difference?
  40. Sway Bar Bushings
  41. FYI Lowered w/ aftermarket struts
  42. K Sport Cobalt SS springs installed
  43. 2009 Brake Vacuum booster
  44. Rear Disc Brakes ?
  45. Monroe-Tenneco Quick-Strut update
  46. Heavy hauling
  47. Apex Springs
  48. Weird squeeking sound when pressing the brake
  49. Low dust brake pads
  50. What's your HHR ride height?
  51. Power Stop Brakes/Rotors..?
  52. Sway bar end links
  53. Cobalt springs?
  54. Doing front hubs
  55. Found the fix
  56. Rear brake noise and slipping
  57. HHR Suspension
  58. Brakes and Struts
  59. HHR Front Discs and Ceramic Pads
  60. looking into performance struts
  61. Squealing, rattling, and annoying
  62. Fill in the Blanks :Best Replacement Parts
  63. Monroe quick struts on hhr.....still a problem?
  64. brake rotor brands
  65. Painting Calipers
  66. Problem with lowering springs, need advice!
  67. Front brakes
  68. HHR SS Front Coils Part Numbers?
  69. wheel lift
  70. Inner Tie Rods
  71. Car lowered
  72. Looking for Factory Ride Height Dimension..
  73. Brembo rotor recommendations
  74. Noise from struts
  75. Changing all 4 original factory struts, help please
  76. SS on BC Racing Coilovers
  77. Drag bags used for towing?
  78. Need front springs for RWD V8 project
  79. Cobalt SS/SC actually lower front?
  80. Bushing interchange question
  81. How much time for new springs to give full drop?
  82. replace bent right lower control arm
  83. Best shock/strut for wifes daily driver?
  84. Leveling dilemma
  85. NOISES with suspension!
  86. Strut Tower Brace
  87. Suspension Opinion
  88. A Few Hub Replacement Pictures
  89. Which parts..?
  90. Bump Stops
  91. Control arm help
  92. Coil spring insulator or seat?
  93. Almost perfect handling
  94. peddersusa.com
  95. Front ssstttrruutttsss,
  96. Pedders 4WD HHR springs?
  97. Springs and stuff
  98. The chase is over......
  99. Front sway bar bushing removal~short cut
  100. My experience with a tire shop and lifetime aligntment/balancing
  101. eibach spings
  102. "4 Play" final mods.
  103. Gold-Lines installed today
  104. Sport suspension to touring suspension
  105. Shocks
  106. Issue with steering wheel pulling to the left while braking
  107. Pedders XA Extreme coilover update
  108. Best Coil-overs for the buck and handling?
  109. Springs
  110. fe5 suspension parts or equal
  111. New tires, struts and shocks.
  112. HHR-SS Frt. end alignment specs.
  113. Clunk!
  114. Birthday present
  115. HHR SS Non brembo Brakes help?
  116. SS rotors on standard HHR
  117. thinking about getting a lowering kit
  118. HHR Front Suspension ????'s
  119. lowest springs I can get?
  120. Powell Race Shop YYZ Springs Review Thread
  121. TTR bar has arrived
  122. Pedders vs Canucks vs Gold Line vs Eibach
  123. front swaybar
  124. shaved door handles
  125. Rear disc
  126. pedder defect
  127. fe1/fe3 shocks
  128. Mild noise front front end
  129. Rear disc option Maybe?
  130. Cobalt SS/TC Shocks and Struts
  131. Looking to get airbags. at least in the back but would like FBSS
  132. Drag bags - leveling bags ?
  133. Lets talk a bout brake rotors,,,,,,again
  134. Eibach Pro Kit Tips/Suggestions Please
  135. Canuck springs installed
  136. Shocks with Springs?
  137. Question about the ZZP rear sway bar.....
  138. HHR SS Coilovers
  139. Getting ready to order MOOG front sways.
  140. Cobalt ss/sc springs installed before/after pics. enjoy ;-)
  141. Soon to be dropped!!! question for members with experience lowering via cobalt ss spr
  142. Need help
  143. Brembos up front, Disc Rear on 06 2LT
  144. lowering springs
  145. raizin stabilizer
  146. Suspension Noise After Drop
  147. Cobalt SS springs and not any lower?
  148. New Struts...now have a creeky noise
  149. Rear Pads and Rotors Part Numbers
  150. Weird noise when turning left, like rubber rubbing on something? Getting louder.
  151. How low can I go safely? 200 mile daily commute
  152. Bigger Rotors!!!!
  153. bagged HHRs click here please!!
  154. Out of round brake drum
  155. airbag/airspring questions
  156. Frustrated about brakes/rotors/pulsing
  157. lowering springs
  158. Strut bushing n bearing
  159. KYB's installed
  160. Lowering springs ?
  161. Koni struts and rear shocks
  162. One of those things that make you go Huh!
  163. HELP cobalt springs
  164. Brake Job Today
  165. Ceramic brake pad vs Standard rotor
  166. Rear disc conversion completed, but soft pedal
  167. Need some suspension help
  168. Lowest i can safely go without bottoming out, ever?
  169. Canuck Motorsports Springs Installed
  170. Lowering Kits?
  171. Eibach Sportline Springs
  172. the ultimate rotor fix
  173. Saturn Ion Redline springs
  174. pedders spring rattle
  175. Strut parts...what's it called?
  176. Strut Time
  177. Front rotor issue solved
  178. Lowering questions
  179. Found source of frt end noise problem.
  180. Brake Questions
  181. SSC Springs
  182. Moog replacement lower control arm bushing
  183. wheel bearing/hub assembly spacer
  184. rubbing noise
  185. KYB shocks and struts for FE5 Suspension
  186. My HHR suspension
  187. SS Struts and Shocks
  188. Front lower ball joint replacement 2006 LT
  189. Rust belt Brembos - brake job - frozen caliper pins!
  190. Aftermarket Springs and Factory Warranty
  191. Brake comment
  192. Sway bar bushing deterioration
  193. Cobalt FE5 vs HHR FE5
  194. Drum Adjusting
  195. New to the Forum
  196. Rotor & pad change
  197. Low dust brake pads for SS?
  198. My testimony!
  199. Sway bar bushings.....HELP
  200. Another complaint about Monroe products
  201. New ebay stoppers installed
  202. Lowering the rear end but not the front.
  203. Lower Control Arm Service Manual Jargon Help
  204. Brake rotors
  205. Rear springs/shocks?
  206. Shock hanging (again)
  207. need lowering help
  208. Torque Doublecheck
  209. Rotor selection
  210. ride height
  211. front wheel bearings vs. struts and tires
  212. What would you do? (struts)
  213. Disc Brake Converstion
  214. Eibach question
  215. replacing struts
  216. Rattles solved...
  217. Looking for a good source and recommendation on Sway Bar Bushings for my 2009 HHR
  218. Need New Rotors
  219. Replaced Control Arm Bushing
  220. lowest you can go without causing damage?
  221. 08 LS HHR braking
  222. Rotors and Pads
  223. Koni Struts IN STOCK!!!
  224. Brake Shoe Question
  225. Brake Drum Question
  226. What is recommended brake pad material
  227. What lowering springs are currently available?
  228. Lowest static drop
  229. Still have rattle in front end
  230. Monroe Vs KYB Shocks
  231. struts replaced again after only 7 months?????
  232. Beefier Suspension
  233. What was GM thinking?
  234. gold line alignment kit
  235. Need ideas
  236. Front Struts - 06 w/FE3
  237. Click in steering
  238. Warped rotors?
  239. Sway Bar Diameter
  240. Installing a Line Loc on 2009 SS
  241. New Rear Springs, which end is up?
  242. centering sleeves on sway bar
  243. Turning slotted/x-drilled rotors
  244. Control Arms
  245. HHR Rotor removal nightmare + fix
  246. sway bar contacting control arm
  247. Rear Control Arm Bushings
  248. How I solved "warped rotor", it's the bushing!
  249. Install for vertical control arm bushing
  250. Thanks guys!
